still no go..help
well i still cant seem to get my truck to run better.. it still runs horrible.. where i need to keep my foot in it to keep it running.. it backfires when i try to rev but its just not running right..filters are not plugged... float isnt stuck.. i have no idea what to do.. new points are in and still not firing right.. any ideas?
1972 C-10...402/400..flowmaster 40 series 1967 Mustang 347 stroker/C-4 1966 Mustang 289/3-speed 2013 Mustang V6/6speed w/300 ponies I may be 23, but i sure do knows 67-72s are sexy! Its not MPG its smiles per gallon! build started 11/25/08 build thread: http://67-72chevytrucks.com/vboard/s....php?p=2993796 |
69 K20
![]() Join Date: Mar 2009
Re: still no go..help
Sounds like an issue with the timing. I am not good at setting this myself so I cant give you good advice on how to do that. I have a mechanic friend who does that for me.
Champagne Taste on Beer Budget
Could have water in the fuel.
Just a thought.
Coming Soon: Project 1970 Country Truck |
Between Trucks...
I'd ditch the points distributor and go with an HEI.
Beat it to fit, Paint it to match... ![]() Last edited by Sinister; 04-16-2009 at 01:54 PM. |
69 K20
hei will come later.. gotta get all the body work done so i can at least get it back on the road...that $100 some can be spent elsewhere
I would check the timing, seems like the timing might be too advanced.
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
whats an HEI?
1971 C-10 SWB - LS swap w/4L60e, 20x8.5front 20x12rear, 1968 C-10 SWB - 454 BB TH350 -Gone! |
Moderator
![]() Join Date: May 2007
Are all of the wires routed to the correct plugs? If they are, my guess is the timing is too far advanced.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
maybe go to the library get a book on how to do a tuneup and read and follow the step by step directions
it has to be advanced..my dads friend came over and put the points in and advanced timing a little because when it cranked it was little delayed.. ill move it back.. i tried starting it little bit ago press gas once and it shoots gas out the carb... i guess i flooded it too haha
it runs like normal.. next thing to fix it has been running so rich lately... like i mean everytime u rev it you smell pure gas...
