Old 04-16-2009, 01:58 PM   #1
MMM...BRAINS...
rear bag differences - RE7's or RE6's??
First off, this site is great! i've learned a ton just searching and reading.
I'm new to the "truck world". I recently pick up a 1960 Chevy Apache Longbed. My focus right now is suspension (air) and steering/handling.
i'm not planning on laying it on ground,....but i want to be a close as i can when aired out. Mainly i don't want to HIT the ground if i have bag,line, or tire failure. but anyways,...
this will be my first bag set-up on a vehicle so i'm trying to soak up all the info i can. so, on to the question...
(i'm planning on running Slams)
i know some of this may be personal preference, but what are the pro/cons of either RE7's to RE6'S in the back?
i've read alot of people on here running RE7's on all 4 courners, and some running 7's up front and 6's out back...
let me know.
thanks in advance,
Chris
"When in Rome we shall do as the Romans,...when in Hell we do shots at the bar."
MMM...BRAINS... is offline   Reply With Quote
Old 04-16-2009, 06:01 PM   #2
protrash64
Resistance is Futile
protrash64's Avatar
Re: rear bag differences - RE7's or RE6's??
I believe the number on slam bags refers to the diameter; the bags are similar in other respects unless you change series of slam bags. I ran re7's all around.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 04-16-2009, 07:07 PM   #3
MMM...BRAINS...
yes, you are right about the diameter, but i figured a different diameter bag would fill differently, different psi @ "x" ride height, and i could see the ride being different between the two.
thanks.
Old 04-16-2009, 07:15 PM   #4
v8blaze
the larger 7 inch bag will require less psi for lift then the 6 inch. this will result in the same ride height with a lower psi and softer ride. Since there isnt tomuch space constraints for the rear id go with a 7. I have them on the front of my s10 and love them
v8blaze is offline   Reply With Quote
Old 04-17-2009, 07:53 AM   #5
MMM...BRAINS...
cool. thats what i was assuming (about the softer ride) just wanted some input. thanks.
Chris
Old 04-20-2009, 08:42 PM   #6
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
I had RE-7s on the back of my 67 & I think that they are TOO soft & bottomed out a lot, so next time Im going with RE-6s
BTW I was running the rear axle about 3-4 inches from the frame (no notch) & I was at like 10 psi IIRC
Just not low enough...
Sinister
Killer
Spray-Bomb is offline   Reply With Quote
Old 04-21-2009, 12:33 AM   #7
gringoloco
A guy with a truck
gringoloco's Avatar
You can remedy this situation by running a 2" drop block. That will allow more air pressure at the same given drop. I run about 35psi at ride height on the rear of my '70 with the axle 1/2" from the frame(or where it used to be- it's c-notched). I pondered running the sixes on my truck, but my frame and notches were already drilled for sevens...
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 04-22-2009, 12:25 AM   #8
beefshreadder116
beefshreadder116's Avatar
i was told by the tech at slam specialties to run re-8's on a fullsize if you have the room fro them, because they take the weight better and should give you a better ride. id call them up, the tech was very informative and didnt try to sell me the most expensive kit they offer. suicidedoors has the best deal on slams bags that i found.
Projects:
66 gmc, SWB ,BBW,76 disc brakes/PS and rearend, pancaked crossmember 2 1/2" drop spindles 1 cut coil, 6" drop coils 2 " blocks c-notch with a 350.
beefshreadder116 is offline   Reply With Quote
