Old 04-16-2009, 02:14 PM   #1
Aarons72
Aarons72's Avatar
Who has the lowest truck w/o bags?
I've got new rims and tires on order and I'm wanting to drop her down a little bit more but I'm not sure how low i can go...When I measure from my license plate to the ground I'm sitting at 6 1/2 inches...I'd love to see how low we can get these trucks w/o bags...let's see some pics of some crazy low 67-72's. I have a feeling I have a long way to go...
Aaron Anderson
*1971 GMC Burban - Daily
*1962 Nova
Aarons72 is offline   Reply With Quote
Old 04-16-2009, 02:28 PM   #2
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Re: Who has the lowest truck w/o bags?
The following two trucks are the lowest that I've personally seen, and they each look killer in their own respect.
Well here's tcb-1's truck with information:
front:
-Summit 3" drop coils for 73-89 GM trucks with a half coil removed
-McGaughy's 2.5 drop disc brake spindles
-1.25" front sway bar
-Tokico drop shocks (still to install)
-CPP shortened sway bar mounts
-Prothane bushings
rear:
-2.25" custom billet aluminum drop blocks
-CPP 6" drop springs
-CPP bolt-in "C" notch
-Early Classic SuperTrac bar
-shock relocators (still to install)
rolling stock:
-235/70/15 Uniroyal Tiger Paw GTS
-rallyamerica.com 15x7 bare smoothie rims
-rear 1" wheel spacers
The front tires tuck inside the wheel well enough that there is no tire rub. The front aligns up correct.
I have not had to modify the bed to clear the rear axle.
I did need to modify the exhaust to dump ahead of the rear axle.
Check out this link for more info...
And here is lolife99's '69 and write up:
The suspension is a 5.5"/7.5" static drop.
I'm using some swap meet '71-'72 McGaughy's drop spindles ($100), a set of $89 Summit 3" drop springs, and my old Belltech drop shocks from the blazer. In the rear I have a set of 6" ECE drop springs, ECE Super Track Bar, and ECE shocks and relocators from my '71 parts truck. I also made a set of 1.5" lowering blocks to get the rear down.
Wheels are a set of 7" and 8" 6-lug ralleys I had, with some Ebay centercaps. Tires are 215/70-15's and 275/60-15's for a little rubber rake.
The front a-arms are the old stock lowers and CPP uppers off of the blazer. All the tie rods, idler arm, etc. are new.
Check out this thread for more info...
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 04-16-2009, 04:19 PM   #3
Aarons72
Aarons72's Avatar
Thanks Nate! That is some great info...
My frame is C notched with lowering springs and the front is 2.5 drop spindles with 3 inch lowering coils. Peace
Aaron Anderson
*1962 Nova
Old 04-16-2009, 06:10 PM   #4
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
My junk is running 3 inch drop springs with 1/2 coil cut, 2.5 spindles for 7 inch total. Rear is 6 inch drop.
It isn't the lowest by any means, but I have driven it 98,168 miles this way on all types of roads, rain or shine.
Old 04-16-2009, 10:00 PM   #5
Aarons72
Aarons72's Avatar
Dude, I like it
Aaron Anderson
*1962 Nova
Old 04-16-2009, 11:23 PM   #6
project 67 sub
project 67 sub's Avatar
cant currently post up to date pics right now(no camera)but the rear of my burb has a 9" static drop: 6" springs 3" blocks. and the front is just cut springs right now(about a 4" drop) but plan on adding 3" drop spindles to that untill i can afford to bag it.
(old pic). here is about where the front will sit when done untill bags.
(here is the most up to date pic i have). this is were the front and the back sits right now, the front is up 3" to high, and the back is tucking a 255/35zr 20 right at the top of the rim
project 67 sub is offline   Reply With Quote
