04-16-2009, 04:07 PM | #1 |
Badass
carburetor
how do i know if my back flaps are opening when i floor it?it dont seem to be opening/
Think outside the box? -84c10 (1stcar)→My Build← -00 Saturn 5spd drop a gear and disappear! 1/4:13:90 |
04-16-2009, 08:11 PM | #2 |
Re: carburetor
It depends, what kind of carb do you have? New? Used? Vacuum or Mechanical?
Usually there is a "kick" when the secondaries open, however, that's also a sign of a deadspot which isn't a big deal but is a pain to get rid off. If anything, you should feel somewhat of a resurgance in power, in other words, it gets noticeably faster. On my Diplomat cop car, I can "hear" it open, you can't rev that high on only the first 2 barrels that quickly when you nail it. If you can't feel a "kick" and your carb runs good, then you have it tuned right and you shouldn't worry. What makes you think they aren't opening?
'69 Dodge Charger R/T 440, 727, 3.55 Sure Grip '68 Plymouth Road Runner 383, 727, 3.23 Sure Grip '89 Dodge Diplomat ex cop car 408, 727, 3.55 Sure Grip '77 Dodge Monaco ex cop car 440, 727, 2.71 '79 Dodge 'Lil Red Express pickup 360, 727, 3.55 Sure Grip '12 Dodge Challenger SRT8 392, M6, 3.92 '85 Chevrolet C-10 SWB 2wd 305, TH350, 2.73 Last edited by 85Bowtie; 04-16-2009 at 08:15 PM. |
04-16-2009, 09:12 PM | #3 |
Re: carburetor
if you have a stock aircleaner flip the lid you'll hear them. like a sudden rush of air. also check to see if your linkage is working with the truck off you'll see them open up. jack
http://67-72chevytrucks.com/vboard/group.php?groupid=37 73 C10 Fleetside If it ain't a Chevy it's foreign http://hotridesmag.com/ |
04-16-2009, 09:35 PM | #4 |
Badass
Re: carburetor
its the stock carb.roghester quadrajet .it has a knn air filter,and i dont feel it open it realy lags when u floor it
04-16-2009, 10:22 PM | #5 | |
Re: carburetor
But with my 4" open air filter when all 4 are open I can physically hear the engine tone change and it makes me giggle like a school kid |
04-17-2009, 07:58 AM | #6 | |
Re: carburetor
Ditch the quadrajunk and get a Holley or Edelbrock. Some people will tell you Q-Jets are great but I've never had any luck with them. They're tempermental carbs and a PITA to rebuild IMO. You could play expert mechanic and learn the tricks and how-to's of the Q-Jet. Or, you could save time and enjoy driving your truck more often by just switching to an Edelbrock.
'69 Dodge Charger R/T 440, 727, 3.55 Sure Grip '68 Plymouth Road Runner 383, 727, 3.23 Sure Grip '89 Dodge Diplomat ex cop car 408, 727, 3.55 Sure Grip '77 Dodge Monaco ex cop car 440, 727, 2.71 '79 Dodge 'Lil Red Express pickup 360, 727, 3.55 Sure Grip '12 Dodge Challenger SRT8 392, M6, 3.92 '85 Chevrolet C-10 SWB 2wd 305, TH350, 2.73 |
04-17-2009, 08:40 AM | #7 |
Re: carburetor
I can build the quadrajet carb to be a amazing carb but it does take alot of work and a good core to use which is getting harder to find at the junk yards. I would suggest using a Edelbrock. I do not care for Holley on a street driven truck. I really haven't had much luck with them. They take alot of work to tune and although it's worth it in the end they are more for getting max power out of a engine and not so good with fuel mileage.
My .02 cents. Good luck.
82 Chevy SWB "OrangeAnimal" Lot of Goodies! Sold 93 GMC 1500 "Angry Red" 383 TBI Powered Fun! 300hp/410ft.lbs. 09 Yaris wife's daily. |
04-17-2009, 09:11 AM | #8 |
Re: carburetor
I'm the opposite, I can tune/rebuild any Holley/Edelbrock/Carter even the thermoquad.
I've got a Holley 870 on my 440 that runs fine on the street or track, doesn't even run slightly rich. Everything else I use Edelbrock. The Q-Jet is a Pandora's Box I am unwilling to open.
'69 Dodge Charger R/T 440, 727, 3.55 Sure Grip '68 Plymouth Road Runner 383, 727, 3.23 Sure Grip '89 Dodge Diplomat ex cop car 408, 727, 3.55 Sure Grip '77 Dodge Monaco ex cop car 440, 727, 2.71 '79 Dodge 'Lil Red Express pickup 360, 727, 3.55 Sure Grip '12 Dodge Challenger SRT8 392, M6, 3.92 '85 Chevrolet C-10 SWB 2wd 305, TH350, 2.73 Last edited by 85Bowtie; 04-17-2009 at 09:11 AM. |
04-17-2009, 03:06 PM | #9 |
Badass
Re: carburetor
yea im thinking about a new carb.but idk if a Vacuum line or something is rong?
on the passinger side under the choke there is a retaner thing that hold the back flap from opening? but when i move that with my finder and floor it the back flaps open? idk if that retaner thing moves my vacuum or what? I've looked all around that thing and cant find out how that thing opens?
04-17-2009, 08:45 PM | #10 |
Right on the line, baby!
Re: carburetor
Sounds like a bad accelerator pump or a clogged fuel filter. Both cheap & easy to check.
83 GMC 406 th400/3.73 Eaton Truetrac posi, headers, x pipe, & racePros. Tubular control arms, lowering rear springs, caltracs. Still ugly, but getting built right, although slowly Click and scroll down for site vendors! Subscribe here! |
04-17-2009, 09:46 PM | #11 |
Kid's Mechanic
Re: carburetor
there is a little spring adjustment on the secondary throttle valve that causes the bog most times
04-17-2009, 10:54 PM | #13 |
Re: carburetor
I always rip off the link that is on the pass. side above the choke housing that goes back to the secondaries on the top. Those things almost always hold the secondaries closed.
I hope that makes sense. |
04-17-2009, 10:55 PM | #14 | |
Badass
Re: carburetor
do u got a pic or somthing
04-17-2009, 11:13 PM | #15 |
Re: carburetor
I found a pic of the link that I was talking about.
04-17-2009, 11:36 PM | #16 |
Re: carburetor
I'll assume you have a mostly stock engine?
The accelerator pump is the rod that's activated by the lever on top of the carb (drivers side). You need to remove the top of the carb to replace it. Also, a dirty carb can also cause poor performance. A rebuilt kit will cost about $20. Here's a great link to info for tuning your Q-jet. You'll see there's text about 2/3rds down the page referring to the secondary air valve that I think Powerdriver mentioned. Mike Ervin's & Damon Nickles' excellent Q-jet tuning tips Here's a link to a parts supplier. carburetion.com
04-18-2009, 12:32 PM | #19 |
Badass
Re: carburetor
me and my dad talked and im just going to buy a new carb. i allready got a performer intake waiting so ill just save up a lil $ and buy something new
04-18-2009, 12:40 PM | #20 |
Parts and more parts
Re: carburetor
Are you absolutely sure that the carb is a Rochester Quadrajet. There is a reason for this question---Carter ALSO made quadrajets and the carter carb has some defiencies in their design. The needles for the secondaries pass through the carb body in openings that tend to errode away and when you accelerate the bogging issue that you described may exist. So to eliminate the bog most drivers would tend to ease through that transition area.
The Rochester carb bodies has a brass insert in that area and did not errode, so the transition from the primaries to the secondaries was better and more prevalent. Also your bogging could be from the surge from your accelerator pump. |
04-18-2009, 01:07 PM | #21 |
Badass
Re: carburetor
I am absolutely sure that the carb is a Rochester Quadrajet
it says Rochester Quadrajet 17082226 1612duu
04-18-2009, 02:39 PM | #22 |
Re: carburetor
Here's the thing, if you have a Quadrajet and the secondaries are opening too soon or not soon enough, and the engine runs good otherwise, switching to a different carb is not the answer. The fact is, the secondary air door on the Quadrajet is easily adjusted to open sooner or later.
1977 GMC Sierra Grande |
04-18-2009, 03:06 PM | #23 |
Badass
Re: carburetor
its not opening at all ,ive been reading up on this carb and they put the same carbs on 305-454s so its way to much cfm for this motor ,thats why the backs are not opening.
04-18-2009, 08:02 PM | #25 |
Re: carburetor
They used Quadrajets of different cfm ratings on 305-454. They are tricky and you have to know exactly what is going on to make it act up.
Another note on your secondaries. They might not open at all when you floor it in park. You need to have load on the engine to make them work properly. If you want to change the carb out then it's not a big deal. There isn't much to it. Good luck hope it makes a noticeable difference.
