04-16-2009, 04:20 PM | #1 |
Truck quit, possible water in gas
So on the weekend I noticed my gas cap was missing. I think I knocked it loose while working on the truck. I have since purchased a new gas cap.
This afternoon I decided to drive my 69 GMC back to work and after about 1 mile it sputtered, then sputtered again, backfired and as I turned a corner it quit. It would not restart. First thought was maybe I have the wrong gas cap and I popped open the gas cap to see if the tank had a vacuum, but it didn't and the clear fuel filter near the carb has liquid in it. Maybe some rain got in the tank this weekend when I did not have a gas cap. Any easy way to pump the water out of the lines? Any other suggestions? I will be walking back to get my truck after work and it would be nice to drive it home. The truck has a 1979 Chevrolet 305 V8, with HEI and a quadrajet carb.
Blaine 59 GMC 9314 a.k.a. Whoopee 68 C20 50th Anniversary a.k.a. The Rat http://www.flickr.com/photos/northerngmc/ http://www.members.tripod.com/P-wee/index_032.htm 1.61803 is one H of a lot better than 3.14159, no really it is! |
04-16-2009, 05:13 PM | #2 |
Re: Truck quit, possible water in gas
Blaine: pull filter out and replace the filter. you could put a hose over the line when it's off the carb and into a pop bottle then crank the engine to see whats in the line. how much rain/snow came down ? and some methal hydrate in the tank to help clear up the h2o
Trueman |
04-16-2009, 05:48 PM | #3 |
There was a little bit of rain one day but I sure didn't think enough to cause a problem. Way less than 1/10".
I will try changing the filter after work.
04-16-2009, 06:10 PM | #4 |
thats enough to do it.
Trueman |
04-16-2009, 08:33 PM | #5 |
Well I pulled the inline filter out and replaced. I took the carb filter out and the parts store did not stock one so I blew into it and air moved through fine. And the gas tasted like gas.
Oh yeah, I added a container of gasline antifreeze. Still won't fire. I even took a little gas and poured it down into the carb and nothing, not even a hint at firing. I am home now and had supper with the family and I am going back to check for spark. Anything to look for with HEI?
04-16-2009, 11:06 PM | #6 |
Trueman |
04-16-2009, 11:12 PM | #7 |
Well good news, I drove the truck home.
I went back determined I was going to pull it back to my house. Of course I had to try a couple more things. Checked for spark and nothing. Took a look at the distributor and the power wire had fallen out! Plugged it back it and it started right up.
04-16-2009, 11:20 PM | #8 |
iam a slow typer was going to say a wire my have come of or broke. good to see your home.
Trueman |
04-16-2009, 11:23 PM | #9 | |
Trueman |
04-16-2009, 11:26 PM | #10 |
I'M TRUCK CRAZY!
I have had that wire fall off a few times... Luckly I knew what the problem was.
04-16-2009, 11:31 PM | #11 |
still better than towing
Trueman |
04-16-2009, 11:32 PM | #12 |
I'M TRUCK CRAZY!
you bet... easy fix i'd say
04-16-2009, 11:36 PM | #13 |
04-17-2009, 12:23 AM | #14 |
Isn't it great to get home under your own power? Makes you feel good to outwit the old truck problems...
