Old 04-16-2009, 08:49 PM   #1
ZombieWeinerDog
ZombieWeinerDog's Avatar
please define a stroker. in terms of engines
1972 longbed- 454
1967 shortbed- 355
ZombieWeinerDog is offline   Reply With Quote
Old 04-16-2009, 08:54 PM   #2
Loki
Loki's Avatar
Re: please define a stroker. in terms of engines
Stroker Motor (def.)
A motor that has greater than stock displacement due to an increase in the factory crank throw. An increase in crank throw increases stroke (the difference between the piston's top dead center and bottom dead center position).
Example. 350cid block + 400cid crank = 383 stroker.
plus any head/block, mods and piston style (dished or domed) to provide clearances or change compression.
Loki is offline   Reply With Quote
Old 04-16-2009, 08:57 PM   #3
ZombieWeinerDog
thanks
1972 longbed- 454
1967 shortbed- 355
Old 04-16-2009, 10:25 PM   #4
BATurbo
BATurbo's Avatar
If you're looking for more info, check out this book "How to Build Big Inch Chevy Small Blocks" by Graham Hansen. It's all about building stroker SBCs. There's a lot of info on each of the main engine components. I'm reading it now and learning a bunch of stuff.
BATurbo is offline   Reply With Quote
