Old 04-16-2009, 08:49 PM   #1
chevyrestoguy
chevyrestoguy's Avatar
What year Seville is a better donor for it's rear disc brakes?
I went 'yarding today after work and found 2 Cadillac Sevilles with complete rear disc brake set-ups. One was a '77 (rear wheel drive) and the other was a '78 (front wheel drive with the funky sloped decklid...ugly)
Are these the same, or is one a better donor than the other. I have read that the '79-'85 Eldorados and Rivieras are good donors, but the rotors on all the ones I have seen in the wrecking yard were 5X4.75 bolt pattern. Maybe I could grab the calipers off those and the rotors and brackets off the '77 or '78?
chevyrestoguy is offline   Reply With Quote
Old 04-17-2009, 10:36 AM   #2
chevyrestoguy
Re: What year Seville is a better donor for it's rear disc brakes?
ttt.
Old 04-17-2009, 10:55 AM   #3
Pyrotechnic
Pyrotechnic's Avatar
http://en.wikipedia.org/wiki/Cadillac_Seville
It looks like you want the first gen RWD one. The article states that 77-79 has rear disc brakes and a 5x5 bolt pattern.
1977 GMC Sierra Grande
Pyrotechnic is offline   Reply With Quote
Old 04-17-2009, 12:39 PM   #4
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
Pyro is correct, 1977-79
Keep in mine the 94-96 HD Impalas (or B/D-body line) had discs also with 5x5.
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 04-18-2009, 03:01 AM   #5
Pyrotechnic
Here's a good write up if you haven't already read it. Apparently 80-85 calipers will work, though I'm not sure about bolt pattern on the rotors.
http://www.73-87.com/7387garage/chas...n/reardisc.htm
Old 04-18-2009, 05:33 PM   #6
Jonboy
Slots go on anything!
Some of the Devilles and Fleetwoods from 77-up had rear discs also. I had a 78 Fleetwood Brougham, and it had a 12 bolt with rear discs.
