Old 04-16-2009, 08:53 PM   #1
blazerbrian72
blazerbrian72's Avatar
Anyone running a xtreme 4x4 comp cam?
im looking for a new cam and i have a 72 blazer with a 406 sb with 202 camel hump heads that i just put on and found out one of my lobes was flat. i had a 280h comp cam in it. i was looking at anstep up with a 292 or an xtream 4x4 cam? just wanted to see if those cams were any good?
blazerbrian72 is offline   Reply With Quote
Old 04-16-2009, 11:24 PM   #2
Captainfab
60-66 Nut
Re: Anyone running a xtreme 4x4 comp cam?
My son had the X4262H in a 406 with Vortec heads and I was impressed with how well it ran. I think you'd be happier with one of the Extreme4X4 cams versus the Magnum 292.
Old 04-18-2009, 01:21 AM   #3
skchevota
skchevota's Avatar
Why did your lobe go flat? was it a new cam? so did not brake in right? Just wondering. I used an extreme 4x4 cam in a 350 and it ran well, I have one for the 408 I am building for my 70, but it will be a while before it is on the road
skchevota is offline   Reply With Quote
Old 04-18-2009, 07:19 PM   #4
mitch1965
mitch1965's Avatar
Comp Cams has a really cool cam selector tool to download off their website. You can select different engines, heads, valves, carbs, etc. After you put in your engine specifics and desired purpose, it will give a list of recommended cams.
'99 K1500 Tahoe, 2dr, barn doors - 350/ 4L60E, 3.73
'01 K2500HD Silverado Ext Cab - 496/ Allison, 4.10
mitch1965 is offline   Reply With Quote
Old 04-19-2009, 10:46 AM   #5
pokethesmot
profeshinaly unimployed
pokethesmot's Avatar
i want one of these cams so bad
"having mud flaps is like asking for a smaller trophy"
pokethesmot is offline   Reply With Quote
Old 04-19-2009, 11:39 PM   #6
shakedown96
shakedown96's Avatar
I have a 274 288 split extreame 4x4 I think. the numbers are fuzzy because we built the engine 9 years ago. not the biggest one they offered but compared to every other 350 I have driven the torq is unmatched this thing pulls to the end of the power curve i love it. matter of fact I thought this truck had 4:11 gears in it it pulleD that good (it has 3:73's) I would not put anything else in a 4x4.
shakedown96 is offline   Reply With Quote
Old 04-23-2009, 10:45 AM   #7
'63GENIII
'63GENIII's Avatar
Extreme 254h in a 396. Great idle LOTS of torque and good powerband. It makes the engine feel alot bigger than it is. Comp also recommends the use of a zinc additive to replace the zinc that was removed from oil due to EPA regs. The story that I got was that most newer engines are equipped with roller cams, making the zinc unnecessary for them, but even well broken in flat tappet cams that have been in use for a long time are going flat due to the lack of the zinc. I'm running Rotella in mine with the additive just in case. I hate changing cams. Especially one that I like!
Chris
'63 k15 long step
Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205
52" front and 63" rear spring swap
D44 / 14bff - disc axles
Milemarker 9K and 10.5K hydraulic winches
63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread
NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build
L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29
'63GENIII is offline   Reply With Quote
Old 04-23-2009, 11:12 AM   #8
blazerbrian72
thanks i think im going to go with the xtream 270/278 dur. thats the biggest that they make for a sbc. it comes out to be a 480/498 lift. the motor was in the blazer when i got it. So i dont know what why the cam went flat. Damm EPA and those damm tree hugger lol. so you live in San Carlos? I grew up in Redwood city and went to woodside highschool
Old 04-23-2009, 02:17 PM   #9
Burt4x4
Burt4x4's Avatar
I run Comp Extreme in my 454. Part number 11-231-3.
It's fairly mild, like an RV type cam.
So far so good although I have nothing to capare it too as this is my first 454 and the only cam I have ran in it.
My engine build was for idel to 5Krpm with contiuious duty in mind so I didn't get too "lumpy" with the cam I choose or I should say the cam CompCam recommended for my specific build.
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks
Burt4x4 is offline   Reply With Quote
Old 04-23-2009, 02:45 PM   #10
blazerbrian72
i wish compcam had a more in the 500+lift for sbc with the extreme 4x4 cams.I live here in CO but im was born in pismo and all of my buddys there have dune toys. so i want something that i can use here and when i go back to pismo i can kick ass lol.
Old 04-23-2009, 02:56 PM   #11
Burt4x4
Burt4x4's Avatar
Well stop scewing around with that SBC and drop a 454 in there
hehehe
I go to Pismo twice a year, Thanksgiving and Memorial and sence I put the 454 in I can keep up with paddeld rigs now well not all of them hahah some of thoes are crazy fast out there
BTW I went to HS just up the road from you Aragon in SanMateo...small world
Old 04-23-2009, 03:20 PM   #12
blazerbrian72
hehehe
lol i was going to pull my 406 and stroke it this last winter. but then work started to slow down and i did not want to put $4000 just in the motor. Now Im layed off due to damm tree huggers now Im try to sell stuff to get parts lol. Yeah all my buddies are running paddels on there rigs. what year where you?
Old 04-23-2009, 03:59 PM   #13
Burt4x4
Burt4x4's Avatar
Year, you mean in HS? Well I graduated in 1986. Damn I'm getting old...
Mine is the green one.
Old 04-23-2009, 04:22 PM   #14
blazerbrian72
lol your just a bit older then me my clas was 1998 lol.
Old 04-23-2009, 04:40 PM   #15
'63GENIII
'63GENIII's Avatar
[QUOTE=Burt4x4;3274459]Year, you mean in HS? Well I graduated in 1986. Damn I'm getting old...
1987 From Carlmont. I'm feeling pretty old now too! Crazy small world!
Chris
'63 k15 long step
Old 04-26-2009, 10:14 PM   #16
skchevota
skchevota's Avatar
Pismo..... I miss pismo. I'm from sanjose. I used to be 2 hours away, now I'm 2 days away.
Old 04-26-2009, 10:36 PM   #17
72blue
72blue's Avatar
I live 10 mins away. I lived to go in HS, but there so many people in atvs that are really young and older ones that are irresponsible (driving crazy) that I haven't been in years.
I graduated in 99 BTW.
On another note, I have an isky 505T and I think it might be a bit wild for me; not sure because I am not done with the rig yet. We shall see.
James
72blue is offline   Reply With Quote
Old 04-26-2009, 11:04 PM   #18
blazerbrian72
Small world! I so lived in greeley and I moved to Grand Junction in 07 for the energy boom
Old 04-26-2009, 11:05 PM   #19
blazerbrian72
whats your name?
Old 11-12-2011, 07:13 PM   #20
caboutin
caboutin's Avatar
I purchased this cam for my big block to replace a very bumpy cam. This cam is much better for my daily driver needs but, it is a little tricky. If you are running a carb, purchase an Air/Fuel meter to tune it. It likes alot of timing so get ready to make all the adjustments. As far as the performance, it placed all the higher rpm horsepower down in the lower rpm range just where I wanted it. But like I said, it takes a little time to figure it out.
caboutin is offline   Reply With Quote
Old 11-13-2011, 03:08 AM   #21
Altec
Getcha Pull
Altec's Avatar
Even Comp Cams doesn't suggest the 4x4 cams. Instead they suggest the Xtreme Energy cams.
Me, I wanna Lunati Voodoo.
'81 K10 454/SM465
'86 S10 Blazer
'95 H-D Softail
'96 Integra
Altec is offline   Reply With Quote
Old 11-13-2011, 10:58 AM   #22
snj8198
snj8198's Avatar
That roller Voodoo series is the route I wish I went. Soon hopefully.
Steve
1971 GMC Longbox. Full Roller Stroker 489 w/ FiTech EFI, Chris Straub Cam/NV4500/205/D60/14B w. Grizzly Locker and 4.11's. 2" Lift on 33's
snj8198 is offline   Reply With Quote
