Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > All 4x4 Tech & Off Roading > 4x4 Projects and Builds
Old 04-16-2009, 09:22 PM   #1
rockn30809
87 resto/build
I'm pretty new here but wanted to share and gather input for my 87 pu build. I've had the truck almost 2 years now. It has been good to me but is starting to show it's age, motor somkes a bit under acceleration, few oil leaks and the trans is acting up. It's going to be more of a mall cruiser with a few trips down very light trails. It is just too nice a truck as a whole to wheel it hard.
Here are some current specs:
swb,350,700r4,np208
new tierod ends and pitman arm
new dual exhaust
New brake system including extended ss braided hoses
2" lift
new shocks and steering stabalizer
new radiator
Swapped factory 3.08 axles for junkyard 3.73 axles
aux battery tray
homebrew brush guard
Future plans:
2.5" shackle flip
add second battery
remove brushguard
add 1" zero rates front and rear
put on some 33"s
replace the rest of the bushings
add sport rear bumper
fix the few rust spots it has
paint and body work
update frontend to 89-91 style
replace all outside rubber
freshen up interior
continue to clean and paint undercarriage
replace trans and motor
whatever else I come up with
[IMG][/IMG]
[IMG][/IMG]
rockn30809 is offline   Reply With Quote
Old 04-16-2009, 10:12 PM   #2
jott_06
Camaro Club
jott_06's Avatar
Re: 87 resto/build
looks like a good truck to start out with
jott_06 is offline   Reply With Quote
Old 09-27-2009, 09:08 PM   #3
rockn30809
Re: 87 resto/build
**Update**
Progress has been slow but here is the few things I've gotten done. Head gasket popped so I had the heads redone, replaced the egr valve, ORD steering brace, scavanged the rest of the serpentine conversion parts(not installed yet), got the 2.5" shackle flip and longer rear shocks(not installed yet). Working on getting the zero rates and u-bolts, then installing the suspension parts. After the suspension I'm going to start on the interior.
87 V10, 350 700R4/208, 373's
Old 09-27-2009, 09:24 PM   #4
Hoods69BadBowTie
Chevys Kick A$$
Hoods69BadBowTie's Avatar
Re: 87 resto/build
Hey sweet looking truck. Looks like its in great shape to start out with at least. Going to look bad when you get it lifted I just love any Chevy or GMC 4x4 lifted . Keep up the good work and post some more pics when u get time.
*HOODS is what I answer too*
-'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold
-'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit
-'86 K5 Blazer Silverado 6.2 4" lift 35"s
-'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's
-'83 Monte Carlo T-Tops. 126,500 Original Miles
-LATER
I would rather push a Chevy then drive a ford!!
Hoods69BadBowTie is offline   Reply With Quote
Old 10-06-2009, 07:35 PM   #5
rockn30809
Re: 87 resto/build
Got the all the parts to do the 89-91 front end swap today. Well, everything except the grill cause it was a GMC. Going to clean everything up and get it ready to go on when I do the serpentine conversion.
Old 10-08-2009, 05:59 PM   #6
84lwb
84lwb's Avatar
Re: 87 resto/build
that truck will look good lifted.mine looks just like it,about a 4 inch lift and 33's.only difference is mines a longbed.
84lwb is offline   Reply With Quote
