Old 04-16-2009, 10:31 PM   #1
SHOWDOG
Cross shaft question
Well, after several years of tearing down,grinding and painting my 67 SS frame,I'm trying to put everything back together. I bought new lower control arm cross shafts and can't recall why there is a dimple in each shaft. Any help would be appreciated.
Showdog
SHOWDOG is offline   Reply With Quote
Old 04-17-2009, 07:35 AM   #2
luvmtrks4366
Re: Cross shaft question
If you look where the cross shafts bolt to the crossmember. Where the cross shafts sits they're is a rivet in the little bracket they bolt to. They sit this way so the shaft won't move around. I hope this helps a little.
luvmtrks4366 is offline   Reply With Quote
Old 04-17-2009, 10:53 AM   #3
Stoney
Farm Truck
Stoney's Avatar
Didi you get them on-line?
Auto parts around here don't have them
1969 CST/10
1984 K5 Blazer 4x4
2016 Dodge Ram 2500 4x4
Mike
Jersey Village, Tx
Stoney is offline   Reply With Quote
Old 04-17-2009, 12:33 PM   #4
70rs/ss
70rs/ss's Avatar
Yep, as he said it, put it together and then install it and tighten the U bolts that holds it to the crossmember, then you can torq the ends on them as well.
70rs/ss is offline   Reply With Quote
Old 04-17-2009, 12:43 PM   #5
bmfpeterson
bmfpeterson's Avatar
Life should not be a jouney to the grave with the intention of arriving safely in a well preserved body but rather sliding in, Goldschlagger shot in one hand, cell phone in the other, body thoughly used up and totally worn out screaming WoooooooooooHooooooooo WHAT A RIDE!!!!!!!!!!
Sorry nothing to do with what you need help with............I have this on a plaque in my house awesome!!!!
bmfpeterson is offline   Reply With Quote
Old 04-17-2009, 05:04 PM   #6
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Whats the torque specs for the caps?
