Old 04-17-2009, 12:07 AM   #1
RonnieTheBull
Issues with a factory tach install???
Ok, heres the deal....I have read the various threads on here and the pther sites about this swap and thought that the clusters after '78 were a plug and play? I have an '83. I did the swap and completed the white face change. the tach works great, speedometer fine but the other gauges I got zippy!! The temp gauge pegs out either cold or hot during cranking and when turned off and while running does a complete 180 and sits in an area that does not read anything. Volts has not mover as of yet, oil pressure pegged out once and has not moved since and the fuel gauge has not moved at all. I'm sure this is an issue that is my fault, I ran a test light to the back of each gauge on the circuit board and they are all getting juice???? I am no electric/wiring guy by anymeans so I was looking for some insight from the vets....what are we thinking??? ground? wiring ??? etc...anything
RonnieTheBull is offline   Reply With Quote
Old 04-17-2009, 01:36 AM   #2
joe6pack
Re: Issues with a factory tach install???
What year is the gauge cluster out of?
Did you ad the tach and move the fuel gauge on a non-tach cluster?
There are different printed circuits for each
I swapped the gauge cluster for the dummy light cluster on my old '69 and had to switch half the wires around in the plug after back tracing
Sounds like there is power to a ground circuit
1977 GMC SWB K15 350/sm465/205
1978 SWB Custom Deluxe Big 10
1978 Suburban Silverado K10 400/350/203
1978 Suburban Silverado 20 "Trailering Special"(parting)
joe6pack is offline   Reply With Quote
Old 04-17-2009, 09:34 AM   #3
RonnieTheBull
I dont have the exact date but I think its out of a '78 or later...my understanding was that these years were plug and play...I changed out the entire cluster...I checked the back of the circuit board and have juice running to all terminals just no accurate readings
Old 04-17-2009, 11:08 AM   #4
rfmaster
rfmaster's Avatar
Based on your description the wiring harness you have incompatible cluster circuit to your existing dash harness. IMHO, plug and play assumes that components in hand are known. This might be not the case, as it is very easy to swap instrument flex circuit and most would not be able to tell the difference.
You need to determine the following:
1) Remove cluster, and carefully map out all the wires going to the plug (note locations and color of wires). Function of each wire can be looked up from FSM.
2) Trace out all circuit traces on the flex circuit. Also note flex circuit part number. Now, you'll be able establish what is wrong - plug to circuit to instrument.
There are over a dozen different flex circuits that can be fitted on the back of your cluster, but only one (maybe two) will work correctly.
//RF
"The Beast"
1975 Chevrolet C20 longbed
350/700R4! with 3inch body lift
Dual Flowmasters Super 40's!
TBI retrofit completed (2007-07-29)
New 383CID (+030) 08-304-8 9.5:1CR x36,005 (2012-12-17)
rfmaster is offline   Reply With Quote
Old 04-17-2009, 12:34 PM   #5
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
It is plug an play in the sense that it is all electronic, not you plug it in and it works. You still need to repin the actual connector. If you had dummy lights before, none of the senders will work either.
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 04-17-2009, 05:31 PM   #6
RonnieTheBull
Yea I was feeling that I would have to re-pin the connector...I had already changed the senders to gauge types...I suppose I will do a search on here to try and find a thread where someone has re-pinned one before...I think I recall a write up on the 73-87.com?? Again I would say I'm far from stupid but this type of stuff really makes me scratch my head
Old 04-17-2009, 05:35 PM   #7
3r!c84
Badass
3r!c84's Avatar
where did u buy it at?
Think outside the box?
-84c10 (1stcar)→My Build
-00 Saturn 5spd
drop a gear and disappear!
1/4:13:90
3r!c84 is offline   Reply With Quote
Old 04-17-2009, 05:40 PM   #8
joe6pack
The gauges and sending units can be fragile when shorted
Hopefully everything is ok
I ended up drawing a schematic for the old cluster and new to keep it straight
That was for a 1969 so not going to help your dilemma
I was interested in where/how much for the white faces?
Please let me know -I'm always looking for a deal
Old 04-17-2009, 05:57 PM   #9
RonnieTheBull
Got the cluster from Carlisle, PA flea market/car show a couple years back
Old 04-17-2009, 06:02 PM   #10
RonnieTheBull
I purchased these over lays a couple years ago from a guy on ebay...here is a link
http://cgi.ebay.com/ebaymotors/1980-...Q5fAccessories
looks to be around $24-25...these actually look a lil better then the ones I purchased back then....I had to cut out the windows for the odometer, light and all...looks like he may be improving in his R&D
Old 04-17-2009, 06:15 PM   #11
joe6pack
Thanks for the link!
Looks to be a fairly good kit -wonder how it will age?
I actually need to swap a tach cluster from my '78 burb to my '77 GMC
I have an early 80's maybe '84 tach cluster but the font didn't match and I knew there would be quite a bit of "custom" work to get the wiring right
At least I have both trucks to figure it out
Not sure how much help I can be without an 80's truck in front of me
Thanks again and good luck -It can be done
Old 04-18-2009, 10:47 AM   #12
RonnieTheBull
not sure how they last installed....hoping they are good for a few years atleast...I know the swap can be done...just gonna take a lil patience and some time on my behalf...probably get started on it next week...thanks for the words of encouragement ...lemme know what ya come with if you pull the trigger on those gauge faces
