04-17-2009, 02:33 AM | #1 |
Wiper motor location
Where abouts is the wiper motor located?
1978 GMC Jimmy 454bbc Turbo400 NP205 3.73 gears 4inch lift 33's |
04-17-2009, 02:40 AM | #2 |
Re: Wiper motor location
Inside the cab,under the dash
04-17-2009, 05:51 AM | #3 |
with a flashlight, you should be able to see the bottom of the motor and the wire harness that connects. Remove 3 or 4 bolts and disconnect the wiper arms before pulling. Pretty easy to do, but don't force anything.
1971 C-10, 406ci, restoration begun! 406ci sb; zero decked, bored .030, edelbrock aluminum e-tec heads, edelbrock performer RPM intake, comp 268 cam, comp 1.6 pro-magnum roller rockers, MSD street fire HEI, MSD 8.5mm wires, Holley Street demon 770, Hedman LT headers. 10.6:1 compression, Air Ride Tech bags on all 4-corners. |
