Old 04-17-2009, 06:33 PM   #1
Chuck78
front disc brake line size, switching from front drums?
If I were to upgrade my front drums to discs, would the factory steel line be too small for the discs? I realize I have to separate the lines at the Tee where the front and rear meet, but the remainder of the front lines, will they need to be ran in larger tubing for discs to function properly?
this was a good post about switching to a dual 4 wheel drum setup vs single reservoir:
http://67-72chevytrucks.com/vboard/s...d.php?t=338777
Chuck78 is offline   Reply With Quote
Old 04-17-2009, 09:37 PM   #2
62 short step
62 short step's Avatar
Re: front disc brake line size, switching from front drums?
The stock lines should be good, I believe they are 3/16 up front.
www.louisianaclassictruckclub.com
1965 c-10
86 chevy c/k 20
62 short step is offline   Reply With Quote
Old 04-17-2009, 10:41 PM   #3
joe231
joe231's Avatar
drums are typically the ones that need larger lines for more volume
CHEVY ONLY
