Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical > Truck Audio
Old 04-17-2009, 07:10 PM   #1
Rollie396
someday it will be done!
Rollie396's Avatar
need some help...
I'm installing a new unit (on the cheap) in my 80.The head unit is a new 4x45 cheapo (with aux jack which is the whole reason I'm doing this).I bought a pair of 5" sony speakers to use on the front channels and am using an old Clarion 10" sub and Alpine 160 watt(?) amp that I've had forever.
I wired everything up going by the instructions provided with the deck and stuff I pulled off the net for the amp.I intended to run the fronts off deck power and sub off the amp by bridging the channels.It's just temporary right now as I wanted to make sure things work...which they don't of course.The amp and sub work just fine,but I can't get the front channels to work.I tested the speakers and they seem fine.I hooked up the craptabulous rear speakers to both the front channels and rear but got nothing.I'm pretty sure my ground is good.It's hooked to the ground block on the a pillar on the driver side under the dash.It doesn't matter if I play with the fader,balance,turn the sub on or off,unhook the sub/amp.Unless I turn the sub off,it always plays but nothing through the other speakers.
Oh and I've double and triple checked my wiring of the speakers and I'm sure it's correct.Help/advice/ideas would be great!
'72 C-10 Proud owner of a million new and used pieces that used to be and will once again be(god willing) a testament to the term "they don't build em like that anymore.
'80 LWB 2wd beater
'67 GMC long fleet (cab donor)
'66 long step (parked till it's turn comes around)
'65 short step (parts truck that will donate it's bed and possibly frame to the '66)
'06 Grand Prix wife's car (she hardly lets me touch it)
my pics
Rollie396 is offline   Reply With Quote
Old 04-17-2009, 09:08 PM   #2
Rollie396
Rollie396's Avatar
Re: need some help...
One other thing,what gauge wire should I use for the power to the amp?
'80 LWB 2wd beater
my pics
Old 04-17-2009, 09:14 PM   #3
Riveted1
Tasty Cakes!
Riveted1's Avatar
Sounds to me like the head unit amp no worky. Can you exchange it for another?
Recommended Cable Size by Power and Distance
Total RMS
Power (watts) Distance
4 feet 8 feet 12 feet 16 feet 20 feet
100 10 gauge 10 gauge 8 gauge 8 gauge 4 gauge
200 10 gauge 8 gauge 8 gauge 4 gauge 4 gauge
400 8 gauge 8 gauge 4 gauge 4 gauge 4 gauge
600 8 gauge 4 gauge 4 gauge 4 gauge 4 gauge
800 4 gauge 4 gauge 4 gauge 2 gauge 2 gauge
1000 4 gauge 4 gauge 2 gauge 2 gauge 2 gauge
1400 4 gauge 2 gauge 2 gauge 2 gauge 2 gauge
Power & Ground Cable Specs
Cable Size
Wire Gauge Current Capacity
Amperage (amps)
1/0 350
2 225
4 150
8 100
10 60
12 40
14 25
16 15
I'm a little and a lot
Ground beef: A cow with no legs.
'66 Chevy SWB "Penny"
'67 Chevy Big Window SWB- aka "Pearl"
'72 Burb- "Betty" "It's not a hearse dammit"
'99 Chevy Ext. cab Silverado
Riveted1 is offline   Reply With Quote
Old 04-18-2009, 01:56 AM   #4
AceX
>130dB Moderator
AceX's Avatar
I'm gonna go with the chart is a little off... 2ga speaker wire?
As far as sizing goes, somewhere in the 10-12 range should work nicely. It doesn't have to be some bad ass wire that's been designed by Robert Zeff and blessed by Steve Meade...
Living Life @ 130dB
LED Tail Light Conversion; How-to
Friend. Father. Brother.
RIP El Jay
CLICK HERE and for less than $0.07 a day, you too can help support and build a better forum.
AceX is offline   Reply With Quote
Old 04-18-2009, 03:21 AM   #5
Rollie396
Rollie396's Avatar
Thanks fellas.I got the speakers working now.Had one hooked up backwards and didn't notice till the fourth check....not sure how I missed that,but at least it's working.
goin by that chart above,and the fact that Alpine suggests a 35 amp inline fuse,12 awg should be fine no?
Another question.What's the difference between running the power directly from the battery and running it from a live 12 volt slot in the fuse block?
'80 LWB 2wd beater
my pics
Old 04-18-2009, 07:49 PM   #6
Riveted1
Tasty Cakes!
Riveted1's Avatar
Uhhh... that's power wire chachi!
Speakers wired backwards? They should have still worked. They would have just moved 'inward' instead of 'outward'. Unless you mean you had both positives going to one speaker and both negatives to another.
And I would bump it up to 10ga. power wire myself for the amp. For the radio, you can just run to the factory fuse block, but the amp should get it's power directly from the battery. Just think about current+resistance=heat=fire=no more truck.
Old 04-19-2009, 12:52 AM   #7
Rollie396
Rollie396's Avatar
Thank you.I did actually end up deciding on 10 awg for the power so all is good.After more playin around with it,I realized that the wiring wasn't the problem (as you suggested),but the spades on one of the speakers was touching the body causing a short.
'80 LWB 2wd beater
my pics
Old 04-19-2009, 10:07 AM   #8
Riveted1
Tasty Cakes!
Riveted1's Avatar
Ya, that sounds more like it. Glad you got it figured out!
