04-17-2009, 09:01 PM | #1 |
Keep On Keepin' On
shock question...
I am doing a 2.5 spindle, 5 coil drop on my 72...I do have an adjustable panhard bar...will I need to do anthing with the shocks..
07 Avalanche Z71 92 Mustang 5.0 GT (Triple White w/ 53,000 miles) 72 SWB Chevy w/ PS, AC, 350/350 Current Project ....In paint shop getting body/paint work done (Corvette Velocity Yellow)... http://67-72chevytrucks.com/vboard/s...d.php?t=157669 |
04-17-2009, 09:13 PM | #2 |
"the other guy"
Re: shock question...
i would like to know as well
God Said,"Building A 10 Second Import Is Like Coming Out Of The Closet, In The End Ur Still....."EXPLETIVE" |
04-17-2009, 09:31 PM | #3 |
Yes, you definitely will need the shock relocator brackets with a 5'' drop. As for the shocks themselves, I would recommend a shock for lowered applications for the valving, but the stockers will physically work.
Chris 74 Custom Deluxe SWB 350/350/3.73’s 99 2wd Silverado RCSB 5.3/4L60/3.90’s http://www.classictrucks.com/feature...short_bed.html |
04-18-2009, 02:18 AM | #4 |
Good question, I have the same, 63 longbed, 5" drop coils, not yet got the shocks, I really wanted air adjustable as i sometimes tow a caravan, looks like im going to have my shocks made to order from Spax (uk)
Any other ideas, ?? |
04-18-2009, 04:57 AM | #5 |
Yes you need new shocks. They will most likely bottom out on the down side. I run the toxic drop shocks on mine. I have a 2/4 and my stockers did not work. The toxics were not the most expensive, but they are firm but not to much and overall ride quality is good.
67 gmc 1/2 ton, 5.0 v6, 4 speed SOLD!! 70 Chevy C-10, 355, th400, 3.73's 2/4 drop |
04-18-2009, 11:37 AM | #6 |
Watch out for your cornhole !
I've run stock shocks on the rear down to a 6 inch drop. But, when I bought the shock relocator kit from Early Classics and their KYB shocks, the ride improved significantly.
Mainly, the shock relocator kit makes the shocks more vertical, which is how they work best.
