column shifter issue
ok when i go to reverse i have to kinda play with the handle to find reverse then hold it there but if i go to drive , 2nd,low it stays fine with out any problems at all
my question is that in the column itself of is that part of the linkage to the trans??? and how do i fix that ??? |
Re: column shifter issue
any one ?? seems like the reverse light dont come on when i find reverse either its just a little past that
Gone to greener pastures
![]() Join Date: May 2007
Can't help ya much, but WTF; WELCOME to the board!
'69 Chevy 1/2 T LWB Stepper: Daily Beater '72 GMC 3/4 T Fleet: Another Daily Beater '72 Plymouth Gran Coupe: ? "Ah women. They make the highs higher and the lows more frequent." Friedrich Nietzsche "Never kick a fresh turd on a hot day." Harry S. Truman GUN CONTROL: Never having to say, "I missed you." Always fire two warning shots into your attacker's chest area before putting a bullet between his eyes. Paraphrased from Louis Awerbuck |
its all about the +6 inches
welcome to the board
This topic has come up a few times in the last week or two. It's due to a poor design, and being 40 years old.\ you can try squirting some lube into the column, like where the shift arm comes out, and then some at the bottom of the column where the shift linkage hooks up (under the hood) if you have someone shifting the tranny (foot on brake, engine off) with you leaning over the fender, it'll be obviouse where to spray the lube. |
