This sounds crazy. Anyone know?
I had a guy at a shop tell me the best way to clean up the inside of a motor is while its running at about 3500 rpm slowly pour about half a quart of trans fluid down your carb. has anyone ever heard of this or done it.
1971 GMC ![]() 1972 Small Blocked DATSUN 240Z Dads old car ![]() |
Re: This sounds crazy. Anyone know?
it will work. i use solvent (varsol) slowly in the carb and keep the revs up,also use sea foam as per inst on the can. the is helps to decarbon the top end of the motor.
Trueman |
It'll smoke like a freight train but it works.
The mechanic that worked in the shop next to mine would always pour water down the carb while he held the rpm up. He claimed it was the only way to clean out the carbon build up.
Parts and more parts
l have done the "liquid valve Job" many times in the past, on older vehicles. It does a fair job of cleaning the carbon from the inside of cylinders and off of valves. The 3500 RPM thing is a little high, though. All you have to do is take manual control of the butterfly on the carb and keep the engnine running while you pour fluid down the throat. Right at the end let the carb choke down and the engine stop. After a slight soak period, take the vehicle and drive it. IF nothing else you will eliminate some mosquitos in your area. Brake fluid works, also, but if spiloled it can be hard on paint.
I have put the fluid in a squirt bottle so I didn't pour too much in at once.
Happiness is towing your "new" truck home. 1972 C-10 1982 GMC (parts truck??) ![]() 1969 c10 parts truck 1969 C-10 ( my sons) 1992 Silverado 4X4 (now the boys truck)(now mine again ![]() 2002 Tarus (my wife loves that car) |
sounds good guys. thanks for the input.
Active Member
![]() Join Date: Jul 2007
ZMax? http://www.zmax.com/why/how_to/
You mentioned "the inside of a motor." Did you mean the carbon buildup on the pistons and valves and combustion chambers or the lubricated part of the engine? The down the carb trick is mainly to clean the engine of carbon buildup and stuck rings due to carbon buildup. It doesn't do anything to the rest of the engine. I like the idea of ZMax for the fuel and oil. Might be something to try. |
i used Zmax once. did'nt do any harm. have used dura lube. these are more a metal treatment or a cover your ass if you over heat or run on low oil psi.
Trueman |
I have used water & tranny fluid I dont know if in fact it did anythng..
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
i know alot of people have used the seafoam stuff, they all say it works.. i would feel more comfortable using it...
1971 C-10 SWB - LS swap w/4L60e, 20x8.5front 20x12rear, 1968 C-10 SWB - 454 BB TH350 -Gone! |
![]() Join Date: Dec 2008
Do not "Pour" anything into the engine, this is the kind of advice that will hydrolock your engine and bend stuff not meant to bend, from what I understan water works as good as anything for cleaning carbon, use a small trickle , too much will hurt the engine. keep revs up as you pour you will hear it bog down, slow the pour down...Water does not burn, but does create a steam thet will take off carbon build up...but in its liquid form cannot be commpresed and acts as a solid and will cause piston to head clearance issues.
#13 | |
Moderator
![]() Join Date: May 2007
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
#14 |
The stuff does work, though. The other answer is to go to a shop and have them run a Motorvac cleaning on it. It puts stuff in the intake as the vehicle is running and gets the carbon off.
#15 |
![]() Join Date: Feb 2009
I think what you are talking about is called FOGGING. There is an actual product on the market that is designed for this. I think AMSOIL carries a "fogging oil" you can probably run a search on that to find the info you are looking for.
1967 C10 LWB 454/TH400 1971 C10 SWB 1984 C30 LWB Dually 454/4 spd 4:10 2003 GMC Sierra 2500HD Crew 4x4 6.6L Duramax/Allison |
#16 |
i know my dad uses it to winterize his boat motor.
1972 longbed- 454 1967 shortbed- 355 |
#17 |
That's right, it's Copper!!
I used to use BG44K. Find a vacuum hose and let it suck the fluid in the motor.
#18 |
I have never used it to clean the inside of an engine, but I have used transmission fluid to build back up the compression on a rotary motor (rx7). Did wonders, but smoked like heck for awhile!
#19 |
BG44K does a nice job....not to sound like a brand whore.
![]() 69 burb/01 yukon chassis 65 Comet Caliente 289 4 Door Sedan 99 Millenia S (supercharged) 4 Door Sedan 02 Yamaha R6 69 swb c10 http://67-72chevytrucks.com/vboard/s...36#post3799136 building with a buddy: 85 C10 http://67-72chevytrucks.com/vboard/s...94#post3708194 |
#20 |
I just poured a bud light down my carb, now the damn thing pulls to the right
#21 | |
I built it
'72 k10 lwb 454, th400, 205, d44ft, 12b rear, 4in skyjacker, 35x12.5-15 superswampers, 4.56, blazer tank. painless wiring harness '98 dodge 3500 12v 5sp 4x4. the truck that actually runs |
#22 |
There used to be after-market 'Water Injector' kits that were said to keep everything nice and clean. Kinda like how you can always tell which is the problem hole if you blow a head gasket and losing coolant into a cyl-that one will be very clean.
I alwaays dump in a quart of ATF in the crankcase if I'm gonna rebuild the motor. Dump it in then go for a 10 or 15 mile drive-that really breaks up the sludge and makes cleaning a breeze.
'68 Panel Project Boogie Chillin' '68 C-10 Ol' Green |
#23 | |
its all about the +6 inches
#24 | |
Gone to greener pastures
It was an after market "sprayer" that had a nozzle going through the top on the air cleaner. If the engine started to detonate, the driver turned on the water & let it spray into the carburetor. A lot of folks made their own using windshield wash pumps instead of paying premium $'s for an aftermarket kit.
'69 Chevy 1/2 T LWB Stepper: Daily Beater '72 GMC 3/4 T Fleet: Another Daily Beater '72 Plymouth Gran Coupe: ? "Ah women. They make the highs higher and the lows more frequent." Friedrich Nietzsche "Never kick a fresh turd on a hot day." Harry S. Truman GUN CONTROL: Never having to say, "I missed you." Always fire two warning shots into your attacker's chest area before putting a bullet between his eyes. Paraphrased from Louis Awerbuck |
#25 |
There was recently a report on tv about the internal engine cleaning some shops are pushing on their customer. They had a lubrication engineer explaining what the shops were trying to sell. He highly recommended staying away from the internal cleaning devises. He stated that they do more harm than good to an engine. He was referring to a newer fuel injected engine, not sure how he would feel about an older carb motor. As for cleaning the lubricated parts, he recommended adding a quart of ATF, when you are going to do an oil change. Warm up the engine to operating temp. Then draining the oil/ATF. He stated that the ATF is more of a solvent than a lubricant, and would help remove built up sludge deposits in the motor. Just thought I would pass this info on.
'72 GMC custom camper 350/350 |
