mystery squeel at start up
I have an 86 Chev PU with 305 V8 that I bought about a 2 months ago.
Has about 107K original miles with no apparent history of any major engine work. At start up there is a high pitch squeel that lasts about 20 seconds to 1 minute and then goes away. It only seems to occur at cold starts. At times the squeel is very load and can really hurt your ears. I have done all of the following and cannot figure out what the source is: 1. replaced water pump & hoses 2. replaced alternator 3. replaced belts 4. disconnected the air pump 5. disconnected power steering Anyone have any ideas on what the problem could be? Thanks |
Re: mystery squeel at start up
Tighten your belts. Sounds like they are the problem.
Rule #1: If it's stupid but works, it's not stupid. |
Robert Olson Transport
![]() Join Date: Oct 2002
the belts may have been loose for a long time and have literally polished the pulleys so that before they get warmed up from the motor heat, they slip and squeal.. you need to take off the belts and use a real light emory cloth and just take the shine off the pulleys then re install your belts and tighten to the proper tension and your squeal should go away
13lazers' blazers
![]() Join Date: Jul 2005
Yup I had the same problem. Make sure all of the required belts are installed. Sometimes the AC compressor binds up, make sure its turned off.
![]() 1970 2wd blazer 1972 1ton blazer 4x4 in progress 1966 mustang coupe (modified) 1985 c20 suburban tow rig 1996 462 ranger with a 150 efi merc. a former B.A.S.S. tournament boat ![]() ![]() |
You could always remove the belt and spin the pulleys to make sure there is no binding. While belts are removed start engine to verify the noise goes away. If the noise does go away remove the shine from the pulleys like Old Rusty said. I use a scotch brite pad (red).
Jeramy '84 GMC project truck '85 Chevy 4X4 SOLD '07 Chevy Trailblazer SS 5th Annual SHPHC Car/Truck Show Pics http://67-72chevytrucks.com/vboard/s...d.php?t=543605 UPDATED PICS! CHECK 'EM OUT |
Badass
old rusty is right
i learned this back when i use to soup-up lawnmowers get them tight or they will howl like a dog until they heat up or when they get wet lol
Think outside the box? -84c10 (1stcar)→My Build← ![]() -00 Saturn 5spd drop a gear and disappear! 1/4:13:90 ![]() |
spray belt dressing on them thats the easy way to find out if you need to pull the belts up to buff the pulleys
my sports car rolls on six wheels only because I'm to fat to get in and out of new corvette http://hubgarage.s3.amazonaws.com/ph...ped_detail.JPG |
78 Big10 454
![]() Join Date: Jul 2008
Had the same problem in my truck. It was the A/C compressor.
Watch out for your cornhole !
![]() Join Date: Jun 2003
I've seen this many times.....fan clutch....replace it and problem solved.
i just get some dish soap and squirt it on the belts makes it smell real good at start up if it's a belt squeal it should go a way then tighten all belts but i would say clutch fan, or ac compressor going
http://67-72chevytrucks.com/vboard/group.php?groupid=37 73 C10 Fleetside ![]() If it ain't a Chevy it's foreign ![]() http://hotridesmag.com/ |
