Old 04-18-2009, 08:18 PM   #1
texastrendz
headers, anyone got the answer?
what i have is a 72 chevy with sbc that is bagged, does anyone know the part number, manufacturer that will fit. i do not need a guess, i figured that someone has a set that fits by now. once again any help would be great, thanks again. i do not want the ece brand or sandersons
texastrendz is offline   Reply With Quote
Old 04-18-2009, 08:33 PM   #2
roofing458
Re: headers, anyone got the answer?
I act like an 11 year old and know how to follow the rules.
roofing458 is offline   Reply With Quote
Old 04-18-2009, 09:00 PM   #3
jlaird
jlaird's Avatar
whats wrong with the sandersons?
jlaird is offline   Reply With Quote
Old 04-18-2009, 11:32 PM   #4
texastrendz
really just the price, i wanted something more wallet friendly if you know what i am saying, i am sure it is a great product, just can not spend that much on headers
Old 04-19-2009, 09:05 PM   #5
jlaird
jlaird's Avatar
I was seriously considering a set from ebay that somebody here recommended that will work on bagged trucks. Let me see if I can find the thread...
Old 04-19-2009, 09:17 PM   #6
jlaird
jlaird's Avatar
this is the thread I was talking about
Old 04-20-2009, 09:34 PM   #7
Riveted1
Tasty Cakes!
Riveted1's Avatar
Search button is your friend, but here ya go:
Headers
I'm a little and a lot
Ground beef: A cow with no legs.
'66 Chevy SWB "Penny"
'67 Chevy Big Window SWB- aka "Pearl"
'72 Burb- "Betty" "It's not a hearse dammit"
'99 Chevy Ext. cab Silverado
Riveted1 is offline   Reply With Quote
Old 04-20-2009, 09:35 PM   #8
Riveted1
Tasty Cakes!
Riveted1's Avatar
FWIW, I have the ECE ones on my '67 (had to b/c of the frame) but I LOVE em. Well worth the $$.
Old 04-20-2009, 10:05 PM   #9
texastrendz
i actually talked to nathan at porterbuilt street rods, i got the answer i was looking for, just wanted a solid answer before i ordered anything, guys i always use the search option on any topic, i like solid info before i do anything, i do not have the patients and money to do things twice. thanks for all the info guys.
Old 04-20-2009, 11:16 PM   #10
oneday
Re headers.Hey guys!I'm totally new at this and don't know how to do anything on this site yet!But i am building a sweet 1972 chevy s/b 2wd (lowered of course)up here in Canada.She's all new rolling chassis and i'm dropping the motor in 2 weeks .(FINALLY!!!)Your discussion on headers got my attention.Does anybody know which headers work best for stock crossmember/cab clearance issues?The drop is 41/2 front,5 rear.I'd like if the collectors were not lower than the front crossmember.(approx.370hp 350 rollerized,flat tops,bored 040.,all Edelbrock HP)Any knowledge is helpfull!
oneday is offline   Reply With Quote
Old 04-20-2009, 11:22 PM   #11
protrash64
Resistance is Futile
protrash64's Avatar
.......oneday. .......unless your engine requires full length headers, use 3/4 or shorties. I used a Summit header for 88-98 GM trucks. Welded up the O2 sensor. Others use Patriot and applications for 80's Camaros work, also. You will be able to route your pipe above the tranny mount to avoid clearance issues. Im assuming the '72 doesnt have that much different than my '64. Holesaw your X-member and pipe on thru.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 04-20-2009, 11:24 PM   #12
oneday
Re: How do i post pictures?Where is the button to start new questions?
I'm new to this site and i love it.I just wish it was simpler to navigate and do things.Is it just me or did anyone else have troubles at first?Maybe i need to spend more time here?
Old 04-20-2009, 11:33 PM   #13
oneday
protrash......thanks for the tip.i never thought of investigating latemodel headers,or camaro.nice truck!i used to have a 64.
Old 04-21-2009, 01:05 AM   #14
Riveted1
Tasty Cakes!
Riveted1's Avatar
The Chevelle shorty headers I posted above will work. Or they make the ceramic coated ones. Sanderson and Doug Thorley make some for our trucks that work well too. As long as you don't have a '67 frame, in which case you'll need the ECE ones or similar.
And if you read the thread jlaird linked to, you would have even more choices.
Old 04-21-2009, 07:57 PM   #15
fixit-p
fixit-p's Avatar
Aren't the ECE headers actually sandersons???
fixit-p is offline   Reply With Quote
Old 04-21-2009, 09:56 PM   #16
Riveted1
Tasty Cakes!
Riveted1's Avatar
I believe so, but they're made to clear the frames on the '67s. Don't know if they're a special make for ECE or one of their standard headers. All I know is that they work
Old 04-21-2009, 10:42 PM   #17
shortbed70
shortbed70's Avatar
I run block huggers on mine and nothing is below the frame.
Troy
1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb
my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884
Big Red Dog build
http://67-72chevytrucks.com/vboard/s...d.php?t=572274
shortbed70 is offline   Reply With Quote
Old 04-21-2009, 11:37 PM   #18
Slik69
that's strange, whenI first got my truck, I wanted to run the sanderson header and called them (spoke to a woman) and she told me they did not make a header for a 69 C10. Should I ask for another application. I was going to order the raw finish and have them coated later.
Slik69 is offline   Reply With Quote
Old 04-22-2009, 12:12 AM   #19
fixit-p
fixit-p's Avatar
I found the lising by engine you be the judge pic 1 is Sanderson CC10 and pic 2 is ECE or is pic 1 ECE and
Old 04-22-2009, 12:32 AM   #20
Riveted1
Tasty Cakes!
Riveted1's Avatar
Old 04-23-2009, 12:16 AM   #21
Slik69
peobably going to ask a silly question, but will the cc10 sanderson header fit a 69 c/10 without issue. I could have swore they told me they did not have an application.. but now that I think of it, it could have been for my other car.
Old 04-23-2009, 08:59 AM   #22
Riveted1
Tasty Cakes!
Riveted1's Avatar
Did you just use those two words in conjunction w/headers?
They fit just fine on my '67, so they should fit on your '69. It's the other way that the problem arises w/the frame with other types of headers. In other words, some manufacturers make them for '67-'72 C10's, but they don't actually fit '67's. But since you don't need the special routing b/c of the frame, there are cheaper solutions for you as noted above in this thread.
Old 04-23-2009, 04:13 PM   #23
ante_up13
I have sandersons and both sides cracked on the rear tubes. I had only a few years of use on these.
By the way, they are for sale!
ante_up13 is offline   Reply With Quote
Old 04-23-2009, 08:34 PM   #24
colin_havens
colin_havens's Avatar
what about the 67 frame is so different that it limits the header options? I have a 67, and I'm almost ready to put my motor back in after a dropped crossmember install, and need new headers. Trying to go cheaper than the ece ones, but still look good with minimum cost. Just want to be sure I get it right the first time
colin_havens is offline   Reply With Quote
Old 04-23-2009, 09:08 PM   #25
Riveted1
Tasty Cakes!
Riveted1's Avatar
The frame is a bit wider in that area. Some people just trim the frame. I didn't. You can look in my build thread to see what I'm talkin bout.
