Old 04-19-2009, 05:47 PM   #1
Charlie Huntington
Interior Color Matching
I recently bought a nice 72 Cheyenne Super 4x4. Originally white and med red, now repainted orange and white. Interior is white door panels with wood grain, white headliner, white sunvisors, black and white houndstooth seat, brown steering column, and darker brown steering wheel. Seat belts are black aftermarket. With the black/white combo what color should the seatbelts and steering column be? The paint code is on the glovebox, where is the interior trim code? Thanks in advance for any help!
Charlie Huntington is offline   Reply With Quote
Old 04-19-2009, 06:23 PM   #2
sjarrett71
sjarrett71's Avatar
Re: Interior Color Matching
If I'm not mistaken, all steering columns were black. Also, from the sounds of your other interior pieces your seatbelts should be white. I think with the white/black seat though, the black ones wouldn't look too bad.
-Scott-
sjarrett71 is offline   Reply With Quote
Old 04-19-2009, 06:31 PM   #3
leddzepp
Moderator
leddzepp's Avatar
I have the Parchment (white) interior as well. I am starting to think that black seat belts were used with the blk/wht houndstooth seat cover. My truck is all original, and I just pulled the black seatbelts the other day. There was caked up lithium grease between the brackets and the body, and it looks to me like that was used when assembled at the factory. The date codes also match the production date of the truck. I know there are also parchment seat belts, but I am thinking those were used with the solid parchment (all vinyl) seatcover.
Hopefully, someone else will chime in with their opinion and experience.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
leddzepp is offline   Reply With Quote
Old 04-19-2009, 07:30 PM   #4
71 super
71 super's Avatar
Only times column was black was if the truck was black or it was a tilt column, non tilt columns recieved the same color as rest of the interior. Your belts could be as mentioned earlier either black or white this is due to the super interior colors - either blue, parchment, green or saddle houndstooth. everything was coordinated from this. My 72 4x4 super had green hounds tooth bench with black accents (door panels, dash, headliner etc.)
67 blue step side- bb
68 gold and white swb cst anniversary
68 custom swb hot rod Ls swap
69 swb cst 6 cylinder/ overdrive
69 black/black cst bb swb
70 orange and white cst Canada built truck swb bb
71 black and white super swb bb
71 red and white super swb
72 green and white super swb 4x4
62 nova wagon 400 series Ls swapped
68 Camaro 327/4 speed- 1 owner, original paint
66 Volkswagen bettle
69 auto stick Volkswagen Beetle
71 super is offline   Reply With Quote
Old 04-19-2009, 07:54 PM   #5
Charlie Huntington
Although I've had this vintage Chevy truck for many years, I've got more experience researching the numbers on GTOs. With the GTO a lot of black accents were used on white (parchment) interiors. My guess is that the black dashpad is correct and that the column and steering wheel should also be black. Please keep the answers coming and I'm also still interested in the location of the trim code. Thanks!
Old 04-19-2009, 08:07 PM   #6
72 Super
72 Super's Avatar
My Black and White Super came with Parchment interior with Houndstooth bench seat. The original seatbelts,dash pad and column are black.
I had a Orange and White Cheyenne with Parchment interior that came with Parchment seatbelts,black dash pad and brown carpet and Brown dash area where the defrost vents are.
Do you have any pictures of your truck?
Ray
72 Cheyenne Super (Purchased new by my parents in August of 71) Black and White
72 Super is offline   Reply With Quote
Old 04-19-2009, 09:05 PM   #7
The column and wheel would be black only if the interior was black or it had tilt.All tilt columns and wheels were black.Exterior paint color has nothing to do with it.
The brown you refer to is a light tan called Sandlewood which would come with a parchment interior.The dashpad would have come sandlewood,too.No parchment steering wheels,column,or dashpad.Those three pieces are always the same color.The seatbelts would be parchment.Seatbelts always matched seat,door panels,headliner,and adashpad/steering wheel/column except with parchment interior.
The top of dash paint color will match the steering wheel/column.The trim code is on the SPID and build sheet between the seat springs and foam.
Old 04-19-2009, 09:30 PM   #8
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
some parchment trucks had black dash pads, some had sandlewood. Look at the top of the dash between the dash pad and windshield to see what color it is. That will tell you what color the pad was originally.
Being that you have a sandlewood column and wheel, I suspect you have the wrong dashpad.
