Old 04-19-2009, 07:28 PM   #1
mycool72
mycool72's Avatar
Need help!
Ok I just installed a turbo 350 longtail trans in my truck. I was told that it was a 3/4 ton trans. Being that I swapped frames on my truck from LWB to SWB I had to get a new driveshaft. The guy I got the shaft from said it was hooked up to a turbo 350 w/ 12 bolt factory rear, which is exactly what I have. The length is perfect but the yoke will not go onto the tailshaft! Is there a difference between 3/4 and 1/2 ton turbo 350's? Do they make a u joint that will allow my larger yoke(fits my trans but not my driveshaft)with larger u joint cap holes fit my driveshaft with smaller cap holes for the u joint?
Any comments or part numbers would be appreicated.
mycool72 is offline   Reply With Quote
Old 04-19-2009, 07:36 PM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: Need help!
Might be something here that will help.
http://67-72chevytrucks.com/vboard/s....php?p=3125931
LockDoc
Leon
Old 04-19-2009, 07:38 PM   #3
seldomseen65
spirit rider66
seldomseen65's Avatar
Location: pahrump, nevada, in the bowels of the Mojave desert
Re: Need help!
local parts house should be able to help you with the swap on the u joint,,Napa auto parts would be a good place to start and any good parts place.
:Chevy: If you don't run your own life,, some one else will.
to our vets,, welcome home,, and thank you for your service.:Chevy:
seldomseen65 is offline   Reply With Quote
Old 04-19-2009, 07:56 PM   #4
mycool72
mycool72's Avatar
Re: Need help!
I've been to the parts store. The u joints they offer have the same size caps, I need large caps on two sides then smaller caps on the other two sides.
Old 04-19-2009, 07:58 PM   #5
rob32472
Re: Need help!
go to a drive shaft place they can help u with this
rob32472 is offline   Reply With Quote
Old 04-19-2009, 11:29 PM   #6
mycool72
mycool72's Avatar
Re: Need help!
I'm planning on going tomorrow, i'll share my findings.
Old 04-19-2009, 11:51 PM   #7
seldomseen65
spirit rider66
Re: Need help!
cool; i had the same problem years ago and did find the right cap like your looking for ,,rob has a good suggestion ,,try the drive shaft place, i think that's were i ended up going. make sure if you go there ,,see if your shaft needs balancing also.
Old 04-20-2009, 06:37 AM   #8
Sammy
Re: Need help!
Good parts store (CARQUEST) can get you the correct u-joint. Lil more I think about $20. Just requires some measuring and a bit of knowledge some special ordering. good Luck.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL"
"You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig."
ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629"
Sammy is offline   Reply With Quote
