Old 04-19-2009, 08:31 PM   #1
allen123
It'll buff out
allen123's Avatar
Bolt on C-notch
I know its a stupid question but Can somebody post a picture of one, I cant figure out how it works. Do you just drill holes then bolt it on the cut the frame?
1972 Chevy c10 swb
2008 CBR600RR Grafitti edition
My Build
Cody Allen
allen123 is offline   Reply With Quote
Old 04-19-2009, 09:36 PM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: Bolt on C-notch
You have to make a template. Then cut the notch. Then clamp the notch in place and drill the holes. (It may take a few clamps) Locating the axle centerline is important also.
Keith
Convert to disc brakes.
Old 04-19-2009, 09:39 PM   #3
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
Re: Bolt on C-notch
by locatting axle centerline what do you mean.....may do a cnotch for mine eventually...
John
1999 Toyota Tacoma 4x4
Old 04-19-2009, 10:00 PM   #4
68 short step
Re: Bolt on C-notch
take the rear spring out, let the frame 'rest' on the axle, and mark the centerline of the axle on the frame, then match-up the CL of the notch with the CL on the frame (you just made), trace the notch (section to be cut) and cut it out.......basically you want the axle to fit in the center of the notch.....hope this helps
68 short step is offline   Reply With Quote
Old 04-19-2009, 10:06 PM   #5
lolife99
lolife99's Avatar
Re: Bolt on C-notch
well said.
Keith
Old 04-20-2009, 08:10 PM   #6
oldblue1968chevy
Re: Bolt on C-notch
so your just lettin it sit lower by letting the axle go into the frame, there fore the c shaped notch in the frame...duhh
is there an advantage to bolt in vs welded in
John
Old 04-20-2009, 09:15 PM   #7
Hottrucks
Redefining LowBudget
Hottrucks's Avatar
Re: Bolt on C-notch
there are 3 rivits for the bump stop and you will find that the top center one ins the center??...I just cut and welded mine tonight so it's fresh in my head
1970 C10 CST fleetside 472 ....big dreams little cash...
SunShine Syndicate..
Mikes Sandwich Fair Run OCT 8th 2011
Hottrucks is offline   Reply With Quote
