67-72 Seatbelt Guru's, shoulder harness???
Just picked these up off Ebay... ad said Nova, Camaro or truck... thoughts? will they work???? pics of original should harness'???
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
Re: 67-72 Seatbelt Guru's, shoulder harness???
Just from the photo they will work but you will need boots to cover at the "B" pillar. The bracket needs to be flat for the shoulder mount.
67 blue step side- bb 68 gold and white swb cst anniversary 68 custom swb hot rod Ls swap 69 swb cst 6 cylinder/ overdrive 69 black/black cst bb swb 70 orange and white cst Canada built truck swb bb 71 black and white super swb bb 71 red and white super swb 72 green and white super swb 4x4 62 nova wagon 400 series Ls swapped 68 Camaro 327/4 speed- 1 owner, original paint 66 Volkswagen bettle 69 auto stick Volkswagen Beetle |
Is the pillar mount two bolt or single?
good question.. I'll send pics when they come in.. If they won't work then i'm sure some Camaro guy will pick them back up. Paid $130 so it wasn't that bad of a deal.
![]() Join Date: Sep 2001
Here is a photo of a pair of black shoulder belts as well as the installed belts. If you can see it there is a dimple near the bottom of the rubber/plastic boot that will hold the male part of the buckle in it and allow you to store the belt when not in use without banging around in the cab. See photos. The plastic plug is removed and a correct seat-belt bolt must be used that will tighten properly and allow the belt to easily pivot on the bolt shoulder.
Moderator
![]() Join Date: May 2007
Hey Dan/Harold- Is this the proper order, and the correct bolt that needs to be used? I have seen where most people have just cut the boot ring. I was looking at it today, scratching my head...I think I got it right.
MSGross- Nice Score! Hopefully this is the right way to install them.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
by work ,do you mean will they save you in case of crash ?? probally not, i wouldnt trust any 40yo seatbelt to do that
I can have them rewebbed if the shoulder belt is "like" the original.. I agree that any dry rotted webbing wouldn't be safe to run and most originals wouldn't survive the tension of a crash due to their age..
Thanks for the pics, I have a feeling that these are for a Camaro but in that case only the shoulder belt would need changed to be correct. For $130 I don't think I could go wrong even if I resell them...
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" Last edited by msgross; 04-21-2009 at 03:51 PM. |
Moderator
Obviously I do not plan to re-use the frayed belt in my pic MSGross...I just want to see if that is the correct order in which to install it.
Scott yes you have the order right. The rubber on the boot acts to protect the paint from scratching the b pillar. Harold
Scott, Harold is right on the money about the order, as usual!
Jeff
I'm not a pessimist, I'm just optimistic that bad things are going to happen. 1971 Cheyenne Super K10 - tilt, cruise, air, am/fm, tow hooks, factory buckets! 1986 Jeep J10 pickup, - 5.3L Vortec with 4L60e and NP241. |
anyone have just the shoulder belts for sale still? I think the NOVA/CAMARO belts have two holes for the pillar... verdict is still out on if they will work or not..
#13 |
Moderator
Mike- The shoulder harnesses are pretty pricey if you can find them. I just posted a thread showing other belts that are very similar that can be used in lieu of originals: http://67-72chevytrucks.com/vboard/s...d.php?t=339651
#14 |
I still trust an unfrayed nylon web belt.I bet if you could pull a truck with these belts.Does everyone have re-webbed belts but me?
#15 |
Moderator
Special K- None of mine are re-webbed. I have pulled a fully dressed big block motor using a 40 yr old seatbelt from our trucks as a strap. If it can do that, I am sure it can stop me from going through the windshield.
#16 | |
I'll post pics when I get this Nova set in..
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" Last edited by msgross; 04-22-2009 at 06:52 AM. |
#17 |
Mike I think that the belts that are located to the inside next to the row of buckles would be the closest set to use for shoulder belts. As scott stated the bracket must be flattened in order to work with the correct boots- you can do this in a regular vice. I have two sets of shoulder belts and sold the set that scott has to him. They are difficult to get more because of the boots than any other reason. My set in the bb truck was sent out and rewebbed by cheyenne superman as were the lap belts simply because the originals were to faded for what I was trying to accomplish. The second set is in very good shape and I have not messed with them. If you ant to get a true set of these you should look in ambulances as I have seen more sets pulled from them than anything else. I think that member uncle has a set but have not seen him on in a while. You can try Roger Koop in Kansas(koop's parts) (near teeitup), Jerry Brown in Tennessee (truck shop), Gary Terry in Texas (CS-M) any of these people may have a set for sale but you are truly looking for a hard to get piece. If you have any questions ask maybe I can help and if you decide to give the belts you bought a try, I think I still have a set of repop boots I will trade for a tilt column pointer, but as stated earlier they are thin and not exactly as original- they are created to replace corvette boots from early 60's. Good Luck with your search and you might also try member Rod as he might have some info that may be helpful as well. Harold
#18 |
so I found out that these were from a 70 nova... everything will work except for the part where the shoulder belt bolts to the cab, these have two bolts..
#19 |
I bought some Hoffman belts to install in a 72 stepside (I will make an introduction post later) and the supplied b pillar shoulder bracket bolt is too big. Can anyone tell me the bolt specs? More importantly can anyone tell me where to find that type of information?
