Old 04-19-2009, 10:32 PM   #1
Mike68stepside
Trailing arms or leaf springs?
I recently bought a 68 Shortbed Stepside. Most that I have looked at had trailing arms, however this one has leaf springs. What can I look at to confirm this is how the truck came or was it changed. How many of you have seen or heard of this?
Mike68stepside is offline   Reply With Quote
Old 04-19-2009, 10:48 PM   #2
67ChevyRedneck
67ChevyRedneck's Avatar
Re: Trailing arms or leaf springs?
Chevy or GMC?
"Typically" 1/2 ton Chevy's came stock with coil springs while 1/2 ton GMC's came with leafs, but either could be optioned with the other rear suspension.
If it was an option, I think it would be listed on the SPID on the glovebox door.
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 04-19-2009, 10:57 PM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
they made millions of C/10 trucks with leafs... not as uncommon as everyone seems to think.
As indicated above, the SPID would tell you if it is original.
Old 04-19-2009, 11:17 PM   #4
mycool72
mycool72's Avatar
Do the hangers have original rivets or are they bolted on?
mycool72 is offline   Reply With Quote
Old 04-20-2009, 01:16 AM   #5
sweet70beast
sweet70beast's Avatar
Not nearly as rare as the 3 door Suburbans.,.,. eh, Longhorn Man?
1970 Nova 327/T5 (my 1st car)
1971 K-20 350/350/205 (winter DD)
1953 GMC Suburban
1968 Chevy Bel Air
1976 Chev C-10
1972 Skylark (suncoupe)
1 of 3943 made
sweet70beast is offline   Reply With Quote
Old 04-20-2009, 01:34 AM   #6
truckster
truckster's Avatar
Or the rare Corvette option... I haven't seen that one for a while.
truckster is offline   Reply With Quote
Old 04-20-2009, 01:57 PM   #7
Mike68stepside
The SPID on the back of the glove box door is missing. Anywhere else I can verify if ordered with leaf springs?
Old 04-20-2009, 01:59 PM   #8
Mike68stepside
Looking at it, they have rivets and not bolted on. Why would you put leaf springs under a 1/2 ton stepside with such a narrow bed?
Old 04-20-2009, 02:13 PM   #9
67ChevyRedneck
You still haven't answered if your truck is a Chevy or GMC. If it's a GMC that's just how they came "stock."
While the coils ride much better than the leafs (IMO), the leafs are much better suited for towing and hauling. The original owner may have wanted to haul heavy loads or tow a lot with his truck.
Jesse James
Project "On a Dime"
Old 04-20-2009, 02:30 PM   #10
mycool72
mycool72's Avatar
Rivets are prob original and factory. Not many people will rivet a conversion, they usually use bolts instead.
Old 04-20-2009, 03:45 PM   #11
Longhorn Man
Back in the day, a lot of people felt that coils didn't belong under a truck, front or rear. Even now, leafs have a huge following in the pick up industry, that's one of the reasons leafs have been used almost exclusivly in the rear of a pick up.
Probably some old timer bought your truck originally and scoffed at the idea of "car springs" under his truck.
Old 04-20-2009, 09:03 PM   #12
Mike68stepside
Sorry, this is a Chevy. The SPID is missing from the back of the glove box door. Do you any where else I might could look to find out if this was the way it was ordered?
Old 04-20-2009, 09:05 PM   #13
Mike68stepside
Thanks for your reply. Hopefully it was ordered this way. Any where else I might find out it was ordered this way?
Old 04-20-2009, 09:27 PM   #14
Longhorn Man
You can rip everything out of the cab looking for a build sheet, but don't hold your breath. In trucks, they are usually stuffed into the springs of the seat, but they've been found under the carpet/mat or stuck to the fuel tank. But again, don't expect to find it.
If it was rivited, then it's probably stock being no one has the equipment to install those rivits, plus, no one would go through the hassle and expense when a nut and bolt would do just fine.
Old 04-20-2009, 09:49 PM   #15
Mike68stepside
You are probably right. The guy before me had started restoring and put in new carpet and seat. The build sheet I'm sure is gone. Just going to assume it was ordered this way.
Old 04-20-2009, 11:44 PM   #16
leddzepp
Moderator
leddzepp's Avatar
I would guess it was ordered that way. I don't know of anyone that would go to the trouble of switching out coils for leafs. I would think it would be the other way around.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
leddzepp is offline   Reply With Quote
