04-19-2009, 11:25 PM | #1 |
Torsion guys, I need your help!!!
I am missing the block that the torsion adjustment bolt goes through on the bottom side by the bolt head.
Make any sense? Is there a supplier that sells these parts? and are new bolts available? Somewhere in the past 40 years, the block on the passengers side became missing. The only thing holding it all up is the bolt head The little square block the bolt goes through is gone........... Idea's?
Tim Road Hounds |
04-20-2009, 03:11 PM | #2 |
Re: Torsion guys, I need your help!!!
Grumpy,
It won't be 100% correct but I had to use grade 8 flat washers to make up the differance until I got a replacements, they are still on. Contact RJ Sisneros on the Stovebolt page BB He's probally got the extra parts you need. Jake Groby
http://s1299.photobucket.com/user/jb...23904108567829 |
04-20-2009, 03:45 PM | #3 |
60-66 Nut
Member ceruzziracing here has a '62 frame that he isn't going to use, you might PM him and see if he'll part with one.
04-20-2009, 04:26 PM | #4 |
Grumpy, drop me a line. Captain is right, my 62 frame is just sitting here, could probably help you out.
