Old 04-20-2009, 12:18 AM   #1
rage777
rage777's Avatar
steering column woes
for some reason, there is a ford column in my 72 c10. i therefore cannot get my new turn signal switch to install along with my aftermarket steering wheel. i've been looking for a stock replacement but they're not cheap and easy to come by. any suggestions for what i can use to replace the ford column? what years can i use in my truck?
1972 Chevy C10 Long Bed
454 Big Block
Turbo 400 3 Speed
Dual Flowmaster
Edelbrock 750 Carb
Power Steering
Disc front brakes
Drum rear brakes
B&M Floor Shifter
rage777 is offline   Reply With Quote
Old 04-20-2009, 05:58 AM   #2
OARNGESI
OARNGESI's Avatar
Re: steering column woes
Do you got a 3spd or automatic if its a 3spd i got a factory column ill give you from a 70
70 SWB STEPSIDE
70 BLAZER
09 challenger
OARNGESI is offline   Reply With Quote
Old 04-20-2009, 10:47 AM   #3
rage777
rage777's Avatar
i have a 3 speed floor shifter. it doesn't matter what i get. tilt no tilt auto or manual column. i just want to get rid of this ford business. found out it's probably a 73 merc cougar column.
that would be great. how much do you want for it? not that it matters, but what color is it? thanks.
454 Big Block
Turbo 400 3 Speed
Dual Flowmaster
Edelbrock 750 Carb
Power Steering
Disc front brakes
Drum rear brakes
B&M Floor Shifter
Old 04-20-2009, 10:50 AM   #4
ZombieWeinerDog
ZombieWeinerDog's Avatar
there is always the junkyard, a column shifter can be very easily converted to a floor shifter
1972 longbed- 454
1967 shortbed- 355
ZombieWeinerDog is offline   Reply With Quote
Old 04-20-2009, 01:48 PM   #5
68SHORTBOX
68SHORTBOX's Avatar
Where in San Diego are you located??? I think I have the orig. column from my 68 around here somewhere.
68SHORTBOX is offline   Reply With Quote
Old 04-20-2009, 02:00 PM   #6
ZombieWeinerDog
be careful with old steering colums. i was putting a new steering wheel on yesturday and the bearing inside the steering column broke apart when using the puller. thats what i get for leaving it outside w/out a hood for 20 years...
1972 longbed- 454
1967 shortbed- 355
Old 04-20-2009, 02:44 PM   #7
rage777
rage777's Avatar
i am actually pretty close to you. i'm in hillcrest.
454 Big Block
Turbo 400 3 Speed
Dual Flowmaster
Edelbrock 750 Carb
Power Steering
Disc front brakes
Drum rear brakes
B&M Floor Shifter
Old 04-20-2009, 04:00 PM   #8
chevygurly
helix makes a decent column..
www.helixsuspension.com/?refid=5010
chevygurly is offline   Reply With Quote
Old 04-21-2009, 10:29 PM   #9
68SHORTBOX
68SHORTBOX's Avatar
Let me dig around in the garage and find all the parts to the column. I am pretty sure that I have everything that you need. Column was in pretty good shape, not alot of slop and every thing was working ok when I removed it. Will try to get you some pictures in the Am and see what you think.
Regards,
Old 04-21-2009, 11:53 PM   #10
So.Cal.Super
It'll Buff Out!
So.Cal.Super's Avatar
Rage777
I might have a spare adapter kit for a grant if thats what your installing. Let me know and you can have it.
"Instructions are just another mans opinion"
Become a Supporting Member
Man Card Rules
http://67-72chevytrucks.com/vboard/s...d.php?t=634550
72 Chevy Cheyenne Super 400 LWB
So.Cal.Super is offline   Reply With Quote
Old 04-22-2009, 01:04 PM   #11
68SHORTBOX
68SHORTBOX's Avatar
Sent you some pic's of the column, check your email. let me know what you think.
