Old 04-20-2009, 12:22 AM   #1
Pont406
th400 reseal
My truck is starting to mark it's territory way to much. It's got a leking rear end from the axle tubes which I will weld during a power trax install. Main oil leak is from a th400 trans. I was going to install 200r4 but my other project is taking all the money right now. So I need to reseal a trans. All I can find is a complete rebuilt kits. Trans is fine only converter makes a little noise. Who sells a reseal kit only? Here are a couple pics and also the one that is taking all my spare cash right now.
Pont406 is offline   Reply With Quote
Old 04-20-2009, 12:45 AM   #2
Lugnut64052
Middle-aged Curmudgeon
Lugnut64052's Avatar
Re: th400 reseal
There are only a few places which normally have leaking problems. You may just have to figure out which one is leaking and replace it, as no one I know makes a kit with just the external seals and gaskets.
The usual places are the pan, rear seal and dipstick tube grommet (from the picture it looks like the rear seal is not the problem). Less often the pump seal (which usually means a worn-out pump bushing) or the shifter shaft seal.
Bret
Check out the site's Truck Tech FAQ.
Be a site supporter.
My more-or-less pathetic build thread.
Board members I've met:
Longhorn Man
Dieselwrencher
jholley
big mike71
Lugnut64052 is offline   Reply With Quote
