Old 04-20-2009, 01:46 AM   #1
cheavy metal
cheavy metal's Avatar
motor I.D.
anybody got any thing on this elusive subject? I checked out year one and nastyz28.com or something like that and if I'm reading it right I think my motor is a 275 hp 327 cid cast/built in canada on august 24 1966. any input or thoughts would be welcome.
66 red and white gmc 350ci 700r trans now a project truck will be my daily driver rat rod
66 burgundy and white gmc 283ci th350 trans gotta ton of good parts current project
old school rulez, West Coast Canadian style
cheavy metal is offline   Reply With Quote
Old 04-20-2009, 10:56 PM   #2
jgh64pkup
Sunburst C10!!!
jgh64pkup's Avatar
Re: motor I.D.
can you post some vin and casting numbers
Gage
1967 C10 Shortbed Stepside
jgh64pkup is offline   Reply With Quote
Old 04-20-2009, 11:40 PM   #3
Captainfab
60-66 Nut
Re: motor I.D.
......And the code off of the pad in front of the passenger side head
Old 04-21-2009, 12:07 AM   #4
oneday
Re: motor I.D.
I simply googled chevy engine decoding and vwalaa.I decoded my engine down to it's original birth vehicle.
oneday is offline   Reply With Quote
Old 04-22-2009, 01:58 AM   #5
cheavy metal
Re: motor I.D.
the front number is K1208HC the problem is all the codes I've seen as examples are 8 digit. as you can see mine is 7 digit. pretty sure its a canadian 327 275hp but I cant tell which car. the date code is h246 which I beleuve is august 24, 1966. 3903352 is the code off the drivers rear.totally in the dark on that one. thanks
Old 04-22-2009, 02:18 AM   #6
originalJD
James
originalJD's Avatar
Re: motor I.D.
year casting# CID HP,low HP,high Main vehicle
1967 3903352 327 210 350 2 cars only
Suffix code...
(K) St. Catherines, Ontario
(1208) Jan. 20 1968
HC 1965 327 Powerglide 275 4 full size
HC 1969 350 m/t 250 2 A F X
Never crush'em. Restor'em or recycle'em. The payoff is always worth it in the end.
http://viewmorepics.myspace.com/inde...lbumId=1709080
http://s258.photobucket.com/albums/h...e_top_view_all
originalJD is offline   Reply With Quote
Old 04-22-2009, 09:59 PM   #7
jgh64pkup
Sunburst C10!!!
jgh64pkup's Avatar
Re: motor I.D.
sounds like it to me
Gage
Old 04-24-2009, 11:04 PM   #8
cheavy metal
Re: motor I.D.
thanks guys
