Old 04-20-2009, 02:50 AM   #1
Hoffman65burb
Hoffman65burb's Avatar
Re-Drilling axle shafts
Hey,
I heard that you could get your 6 lug axle shafts redrilled by a machine shop to 5 lug. Is it cheaper than just buying new axle shafts? any downsides to doing this? Whats the processs the machine shop goes through to do this?
thanks
1978 GMC Jimmy
454bbc
Turbo400
NP205
3.73 gears
4inch lift
33's
Hoffman65burb is offline   Reply With Quote
Old 04-20-2009, 04:52 AM   #2
JimKshortstep4x4
Re: Re-Drilling axle shafts
It is probably cheaper to drill new holes then to buy new axle shafts. The machine shops lay out the 5 bolt pattern on the flange and drill the right size hole so that the studs will press in place.
Before having the axles drilled make sure that the bearing surfaces are good.
If you are looking at doing it to the 69 listed in your signature it probably has the shorter axles so you would want to make sure of the availability of axles if you are looking at that option.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 04-20-2009, 07:09 AM   #3
cdowns
cdowns's Avatar
you might also give some thought as to the brake drums too//check bearing surface of axels also the spline condition
Old 04-20-2009, 12:35 PM   #4
psmall000
psmall000's Avatar
Keep in mind that anytime you drill on a powertrane component, you weaken it, so if this truck has anykind of decent power, say 300 +, you might want new axles.
psmall000 is offline   Reply With Quote
Old 04-20-2009, 03:19 PM   #5
neonlarry
neonlarry's Avatar
Also IIRC at least one of the original stud holes will have to be welded.
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights
99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs
95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI
neonlarry is offline   Reply With Quote
Old 04-20-2009, 08:33 PM   #6
Hoffman65burb
Would is be wise to buy used 5 lug axle shafts from at 67-72 pu?
1978 GMC Jimmy
454bbc
Turbo400
NP205
3.73 gears
4inch lift
33's
Old 04-20-2009, 10:46 PM   #7
low'n slow
Too Dumb To Know Better
low'n slow's Avatar
Late 1970 rear ends and after are wider and you need to find different drums to fully engage your brake shoes. Some people just stick the old ones on, but it's not what I would do.
low'n slow is offline   Reply With Quote
