Old 12-25-2002, 04:19 PM   #1
Jwill41
Jwill41's Avatar
stalls to the left
HELP! My 67 stalls when i go around a left turn. It had an excell coil mounted at an angle for many years. I mounted it straight while I was doing some "clean up". Could the coil possibly be the problem. I was told there was some kind of oil inside. Could this be the problem?
http://www.picturetrail.com/jwill41
67 1/2 ton GMC short step side
68 1/2 ton Chevy long fleet side
72 1/2 ton Chevy Suburban
99 1/2 ton Chevy Suburban
founder (and only member) of the primer/clearcoat club
Jwill41 is offline   Reply With Quote
Old 12-25-2002, 04:49 PM   #2
jhow66
jhow66's Avatar
Are you running a Edelbrock carb? If so you need the off road needle for floats. (spring loaded) --part# 1465
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 12-25-2002, 04:54 PM   #3
Jwill41
Jwill41's Avatar
Thanks! Yes, i am running edelbrock #1405. Can i get this part at a regular parts store or does it need to be a speed shop?
Old 12-25-2002, 05:01 PM   #4
jhow66
jhow66's Avatar
Speed shop--It sounds like one of your floats are to high on one side . When you install new needles and seats, be sure and set floats as instructed. These carbs are very finicky about float height. Good luck.
Old 12-25-2002, 05:08 PM   #5
Jwill41
Jwill41's Avatar
thanks
