Old 04-20-2009, 04:03 PM   #1
38chevyhotrod
38chevyhotrod's Avatar
wind noise reduction?
Past weekend I went to a meeting for the first time with my suburban.
This was also the first time to drive longer times at highway speeds.
At first I thought I could just ignore it after a while but I started getting more and more annoyed by the wind noise at my front side windows.
I cant really pinpoint where the noise is exactly coming from.
Does any of you guys have the same problem? I did put all new weatherstripping in the burb.
Is there anything that i can do about it other than stay under the 50 to 60 mph?
Anybody can restore a classic, takes a man to cut one up.....
http://www.arnoldscustoms.com
38chevyhotrod is offline   Reply With Quote
Old 04-20-2009, 04:13 PM   #2
Hart_Rod
Hart_Rod's Avatar
Re: wind noise reduction?
The previous owner of my suburban sealed the wing vents up with clear polyurethane, . No wind noise, but............ Or you could always do what I do for most anoying rattles or noises - turn my stereo up louder, .
Hart_Rod is offline   Reply With Quote
Old 04-20-2009, 04:19 PM   #3
38chevyhotrod
I taped one window vent off to try if that solved the problem but it didn't help.
That stereo thing sure helps, I did that because otherwise I would have gone crazy.
It also solved the problem of my wife talking too much, I could not here her anymore because of the loud music.
Old 04-20-2009, 05:51 PM   #4
DANTIP
DANTIP's Avatar
New vent window rubber has fixed mine. I hate the work and frustration related to replacing vent window rubber, but, I hate wind noise even more!
DANTIP is offline   Reply With Quote
Old 04-21-2009, 12:45 AM   #5
4x4Poet
Clip on vent shades work great. I can crack a window up to about two inches with little increase in wind noise.
New factory style door rubber made a difference, as well. I did each at different times so I was able to note both improvements. Now I still have some wind noise, though much less than before the two improvements. I want to switch to clip-on door rubber next. Thicker stuff for better sealing.
'71 GMC K20 Suburban, '71 GMC K10 Suburban, '72 Chevy C10 CST Suburban, '72 Chevy K20 clunker pickup.
4x4Poet is offline   Reply With Quote
Old 04-21-2009, 04:37 AM   #6
Andy4639
Old member
Andy4639's Avatar
Putting new door seals in on the 71 truck back when I had it repainted was nice. After a bunch of drives with the wind noise I got inside the truck and looked real good around the seal. The back side of the door that opens I found the seal lip was bent in to much. I took a block of wood and a hammer to it and it stoped the noise. Take your finger and if you can press the rubber and see daylight then this trick should work for you.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 04-21-2009, 05:58 AM   #7
Is it whistling or just humming a tune?I guess I`m used to these old vehicles and still amazed how quiet newer trucks are.I added vent shades to my`92 so I could hear wind.
There`s always the 1pc. conversion?
Old 04-21-2009, 09:42 AM   #8
68gmsee
Active Member
68gmsee's Avatar
Originally Posted by 4x4Poet View Post
..... I can crack a window up to about two inches with little increase in wind noise......
Mine has so much wind noise I could open them all the way and not notice a difference.
I agree with special-K. Most of these trucks were not made for highway creature comforts and I doubt the engineers put them through wind tunnels for noise testing.
Some wind noise I just put up with... That's the way trucks were when I was growing up.
68gmsee is offline   Reply With Quote
Old 04-21-2009, 10:55 AM   #9
Skirkpat
Skirkpat's Avatar
Drill a couple of small holes in your exaust pipe, right in front of the muffler, or better yet, just cut the muffler off....it won't solve the wind noise, but it will be lower on the " annoying sounds" list !!!
The list will now be....
1) Exaust too loud
2) Wife complainig about # 1
3) wind noise.....................
See now the wind is hardly even worth mentioning !!!
Skirkpat is offline   Reply With Quote
Old 04-21-2009, 10:59 AM   #10
38chevyhotrod
I have all new rubbers in the suburban, that means new vent window rubbers also. There is no air coming in to the cab but it is only the noise of air whistling around an edge or something.
Of course I understand that it is not a new truck and there is more noise that modern cars but i was wondering if there is something that can be done to reduce it without ruining the looks of a clean cab.
I did notice that the upper front edge on both doors stick further out than they should be. I had to fill the rubber to make sure it closed up good.
Old 04-21-2009, 11:42 AM   #11
38chevyhotrod
Do you have pictures of that.
Old 04-21-2009, 06:38 PM   #12
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
You also need to remember that the sound deadening in newer vehicles is more thorough.There's no insulation/sound deadening material in the roof,doors and less in the floor than newer rides.You also have the mirror differences and they may be some of the problem.So the noise you do have is not muted by these things.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 04-21-2009, 07:47 PM   #13
bigsnookmaster
bigsnookmaster's Avatar
I agree with PanelDeland.Sound deadener in all the right places will make alot of the noise go away. I used Second Skin Damplifier Pro throughout my cab,under the dash,on the inner firewall,and on the inside of my doors.M<ade a real big difference.Also check for any open holes in the firewall or floorboard,etc.My .02 Good Luck
bigsnookmaster is offline   Reply With Quote
