Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1960-1966 Chevrolet & GMC Pickups Parts Board
Old 04-20-2009, 08:40 PM   #1
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Want to buy: front frame crossmember (under radiator)
My front radiator support crossmember on my 63 is flat messed up. I'd like to buy a good straight one.
Old 04-20-2009, 08:47 PM   #2
LILRED66
LILRED66's Avatar
Re: Want to buy: front frame crossmember (under radiator)
With or without radiator cradles? 2 core or 4 core radiator? I have all of the above. $50.00 shipped. Let me know if I can help and thanks for the opportunity.
LILRED66 is offline   Reply With Quote
Old 04-21-2009, 06:09 AM   #3
Tx Firefighter
I appreciate your quick response.
I will need to figure out exactly what I need. I do know that I am putting my engine in the forward set of mount holes, similar to 67-72 models. So, I guess I will need to have the higher, front radiator mounts. I'm pretty sure I will need both lower saddles and the upper retainer too.
Tell me how to measure my radiator and I will get more specifics to help us decide.
Old 04-21-2009, 08:25 AM   #4
LILRED66
LILRED66's Avatar
Kevin:
To determine the size of your radiator, take off the cap and count the number of rows of cores (small holes in the top) and also measure the width of the top and bottom tank. This will determine the lower tank cradles and the top radiator mount size. After you determine the radiator size, I will figure out which parts you need and reply accordinly.
Thanks fo the opportunity and let me know if I can help you with these items or other good, used 4-5-6 Chevy truck parts in the future and thanks for the opportunity.
Old 04-21-2009, 11:13 AM   #5
Primered_69
Primered_69's Avatar
I believe their are some of these at Little John's Junk yard 121 and Carson or AB's on Riverside and 30
1969 Chevy LWB - with shaved handles; 3 1/2 front/ 5 1/2 rear drop; (waiting to be put back together)
Primered_69 is offline   Reply With Quote
Old 05-13-2009, 08:54 AM   #6
70 Suburban
Rods
I also have one
Just keepin it simple.
1965 C-10 Ext cab build. 350??(Does it count at 2 truck if I had to cut one up?)
1966 C-10 lwb 283 auto
1970 Suburban in pieces
1971 Blazer 4wd....restore someday. all factory CST
1972 Blazer 4wd parts truck still a roller
1972 GMC Sierra Grandee
1998 Chevy ext driver.
2005 F**D the wife drive...(cant fix women)
70 Suburban is offline   Reply With Quote
Old 07-28-2013, 11:57 AM   #7
ambros
I am also looking for front frame crossmember
ambros is offline   Reply With Quote
Old 07-28-2013, 11:59 AM   #8
ambros
It is for 1965 c10
