Hey fellers got another problem.
My fuel gauge stays on empty. I have checked all the connection. But it does not move. Until I unpluged the wire from the fuse box. When I did this the fuel gauge went pasted the full mark. Have any you fellers had a problem like this? Any help would be appericated. redneck_chev
1967 Chevy C-10 fleetside SB 3speed on column Corvette yellow#35 Black W/Red Metal Flake int. looks like Black cherry Diamond White Pearl /Grille Jenson CD system Wooden bed |
i had the same problem with my 71. went for 3mo without a fuel gauge. i ran a test wire from the sending unit to the terminal in the fuse box and it worked! come to find out when i pulled the tank to claen it and put it back in i pinched the wire between the tank and the mounting tab(lol). it had grounded the curcit and made it rean no OHM's. i got the wire out from between the pieces and taped it up, its been working fine ever since. you might want to check it for a bad spot in the wire somwhere or pinched and grounded.
I will check the wire tomorrow. Thanks rayville body, I hope this works.
Thats the Hillbilly way
redneck_chev
You might want to unplug the brown wire on the sending unit on top of the tank. If the gauge goes past full you have a bad sending unit or the float is full of gas. If it stays on empty the wire is grounded.
BILL Torrance Calif 90504 Member DUF Club Member Old Farts Club 72 3/4ton Custom Camper BB402/400 trans Dynomax Cerama-coat headers , Hei distributor ,Edelbrock 1411 air,ps,pb,leafsprings ,98 chevy 60/40 seat,S10 shoulder belts tilt,3.54 Dana 60 rear. 16" Eagle wheels with LT265/75 16 tires,Gaylord Lid,H4 headlights with 100W relay conversion. " If I knew I was going to live this long I would have taken better care of myself " Marriage changes passion...suddenly you're in bed with a relative. A GUY'S PRAYER.... Lord, I pray for a nympho with huge boobs who owns a liquor store and likes to fish and hunt and has a Harley .Amen , |
The float has a hole in it. Thanks for the help. I dont know what I would do with out you guys. Now I have to find a float around here. Or can I fix this float.
redneck_chev BTW-personal thanks to this website and all members.
I would just get a new one , test it B4 you install it.
Good Luck
