I have a 82 Silverado but have always been a fan of the 73-80 front ends. I was wondering if everything would line up correctly between the 2 front clips because my buddy has a front clip off of a 75 that he will give me due to the fact that the fenders need replaced because of rust.
thanks for your help ![]() |
Happy to be here
![]() Join Date: Mar 2000
Re: Back dating a box body
Yes it will bolt up. There will be a couple of issues that you need to address.
The 73-80 bumper is shaped different and so are the frame horns. You can cut them off the donor truck and add them to your 82. Wiper stands are different as well. You will need to use the earlier stands. Get the body bushing from the donor clip too. Anything I am forgetting?
Thanks for the info
It'd be alot cooler if you did
6.0 powered square
I would also use the 73-80 interior
79-80 dash, and 77-80 door panels with the correct door handles
Aaron 1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326 |
