Old 04-21-2009, 01:40 PM   #1
69time
69time's Avatar
12 volt supply
Trying to connect my holley 600 choke wire to a 12volt source other than my ignition wire. Don't want to steal voltage from my distributor.. Anyone know of another wire that supplies 12 volts only when the ignition is on?
69time is offline   Reply With Quote
Old 04-21-2009, 02:41 PM   #2
El Jay
Gone to greener pastures
Re: 12 volt supply
Unless you have an HEI, your ignition wire is only about 9 V.
Putting that aside, you should be able to pull a switched 12 V source off your fuse block, someplace.
I'm not trying to be a hard a**, or a butthead, but you can pull off of other circuits there.
I hope that helps you at least a little bit.
LJ
P.S. Welcome to the board!!!!!!!!!!!!!!!!
'69 Chevy 1/2 T LWB Stepper: Daily Beater
'72 GMC 3/4 T Fleet: Another Daily Beater
'72 Plymouth Gran Coupe: ?
"Ah women. They make the highs higher and the lows more frequent." Friedrich Nietzsche
"Never kick a fresh turd on a hot day." Harry S. Truman
GUN CONTROL: Never having to say, "I missed you."
Always fire two warning shots into your attacker's chest area before putting a bullet between his eyes. Paraphrased from Louis Awerbuck
El Jay is offline   Reply With Quote
Old 04-21-2009, 02:54 PM   #3
berencam
berencam's Avatar
Re: 12 volt supply
kinda on the same line, i converted to hei, and an electric fuel pump. i have 1 12 gauge wire routed from the ignition, to the right side of the engine where it splits into 3 leads, 1 to hei 1 to choke, and one to pump. that be ok to run that much amperage through that one line? Or should i install some relays and wire directly from the batt?
69 chevy c10 350 3 speed manual wood bed build thread here r.i.p.
70 c10 auto 350 build here
berencam is offline   Reply With Quote
Old 04-21-2009, 03:01 PM   #4
Sinister
Between Trucks...
Sinister's Avatar
Re: 12 volt supply
I'd run the fuel pump off a relay at the very least.
Beat it to fit,
Paint it to match...
Sinister is offline   Reply With Quote
Old 04-21-2009, 03:05 PM   #5
americanmusc1e
americanmusc1e's Avatar
Re: 12 volt supply
get a voltmeter and check the open spades in your fusebox for 12 volt sources that come on when your headlights do
-- Josh
Instagram: @americanmusc1e
OLD SKOOL-- 1970 C10. 454/Th400/3.07 posi Build Thread
FARM TRUCK----1949 Chevrolet 3800 Power Wagon Hauler Build Thread
1999 4wd OBS Tahoe - daily.
DM me if you can't see photos i posted
americanmusc1e is offline   Reply With Quote
Old 04-21-2009, 03:10 PM   #6
Sinister
Between Trucks...
Sinister's Avatar
Re: 12 volt supply
You actually want a key on source. You can put on your head lights with the key off.
Beat it to fit,
Old 04-21-2009, 03:14 PM   #7
berencam
berencam's Avatar
Re: 12 volt supply
there should be more than one ignition lead coming off the ignition switch you could run it off that.
Old 04-21-2009, 03:20 PM   #8
Elephanthead
Re: 12 volt supply
There is a switched connector in the fuse box, run off of that, you don't need the full 12V for a choke, just enough to heat up the element.
Elephanthead is offline   Reply With Quote
Old 04-21-2009, 03:51 PM   #9
69time
69time's Avatar
Re: 12 volt supply
Well, I'm kinda just shooting in the dark here. When I initially installed the Holley 600 I connected the choke wire to the ignition, cranked it and it idled up as it should have then settled back down once warmed up. Did this for two days and now it seems that the choke is not responding at all anymore. So I read the carb manual and read where it stated not to use the ignition wire as the source but to find an alternative 12v ignition activated source and here I am.. I don't have a meter to meassure the open spade in the fuse box and I have upped to the HEI..
Old 04-21-2009, 04:55 PM   #10
sleepertruck72
sleepertruck72's Avatar
Re: 12 volt supply
69time,
I'm sure the HEI will like the 12v.
You could get a meter at Wal-mart for around $10. There not the fanciest, but they work and you can keep it in your truck.
72 C20 Longbed
05 1500 Z71
sleepertruck72 is offline   Reply With Quote
Old 04-21-2009, 05:08 PM   #11
El Jay
Re: 12 volt supply
Originally Posted by sleepertruck72 View Post
69time,
Yeah. The HEI requires 12 V to work right.
Do you really need a choke down there in TX?
Up here where I live, It sometimes gets down into the freezing range, but not real often. The choke on my Chevy is blocked open.
When it's really cold, I just pump the throttle twice & then hold it about 1/2 way down. When I hit the starter, it generally fires right off. Sometimes, I admit, I have to crank it a bit; but not real often.
Old 04-21-2009, 06:34 PM   #12
americanmusc1e
Re: 12 volt supply
whoops, sorry I meant to say Ignition.
-- Josh
Old 04-22-2009, 08:59 AM   #13
69time
69time's Avatar
Re: 12 volt supply
I guess not but why would it act like that? I mean, the choke seemed to work when I first put the carb on (idleing up on startup and then backing down when warm) and now not doin that at all.. Just makes me think that something is not quite right..
Old 04-22-2009, 09:09 AM   #14
sneakysnake
It's a catastrophic success.
sneakysnake's Avatar
Re: 12 volt supply
You should have "ign unfused" that is key hot, just use an inline fuse.
sneakysnake is offline   Reply With Quote
Old 04-23-2009, 09:11 PM   #15
americanmusc1e
Re: 12 volt supply
thanks for posting the picture of the fusebox. mine got overspray on it and you can't read it. I have to guess where everything goes.
-- Josh
