Old 04-21-2009, 03:19 PM   #1
woodwright
Enjoying left field
woodwright's Avatar
draglink welding
Is the center link cast? Would it be OK to weld on it? I need to make a new center link and I was thinking of cutting the ends of the stock one, and useing a piece of 1 1/4 DOM.
Clint
70 Chevy 4WD "Ultimate Work Truck" SOLD
woodwright is offline   Reply With Quote
Old 04-23-2009, 11:08 AM   #2
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: draglink welding
Any of you welding experts have an answer?
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 04-23-2009, 11:22 AM   #3
SCOTI
SCOTI's Avatar
I know drag-links can be welded on because I've seen pics on the net where people have modified theirs. I also know (from researching this mod) it's not acceptable in the eye's of many state DPS officers.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 04-23-2009, 07:57 PM   #4
woodwright
Enjoying left field
woodwright's Avatar
I think I'm gonna go a different way with it. I'm gonna use all heim joints instead.
Clint
Old 04-23-2009, 08:14 PM   #5
LMDGUY
LMDGUY's Avatar
Iv seen off road shops weld on the to add steering stabliser (sp?)
1973 C10 "Chain Reaction"
Street Trucks cover Feb 2012
2013 Silverado
1964 Cadillac
LMDGUY is offline   Reply With Quote
Old 04-23-2009, 08:42 PM   #6
Twisted Minis
Twisted Minis's Avatar
I would just run rod ends like you said, and build one from scratch. It will look better anyways.
But I have modified a few. Most of them are cast steel as far as I know, the ones I did where. I basically clean them (sand blast) and then grind them until they are smooth and the cast texture is gone. I bevel everything pretty deep, and pre heat them with a torch and TIG them with a 312 stainless rod.
If you can find it cheaper, I can fix it!
Twisted Minis is offline   Reply With Quote
