Old 04-21-2009, 04:01 PM   #1
65fleet
65fleet's Avatar
front suspension...
im new here to the forum, and i know that this has been talked about a million times but i havnt found anything specifc to my question..
i recently bought a 65 swb fleetside!!!! (wanted this body style scince the early age of 14)
ok heres the deal....... i plan on eventually putting a fair amount of hp in this truck and drum brakes+ speed = getting to know the sand pit at the end of the drag strip...
i have a 85 chevy truck in the yard wasting away... ive read about using the disc brake set up off these trucks as a bolt on swap...
now my question is... can i just un bolt the crossmembers of each truck with all suspension in place and swap them?? i dont mind drilling a couple holes if thats all it takes... id rather do that then pull springs and what not... and id also llike the 85 to be able to roll around the yard instead of sitting on jackstands with no wheals...
thanks!!!
65fleet is offline   Reply With Quote
Old 04-21-2009, 04:05 PM   #2
ob1monkey
Re: front suspension...
I would just undo the spindle with a jack under the control arm and swap them then once the ball joints are back on remove the jack.
ob1monkey is offline   Reply With Quote
Old 04-21-2009, 04:10 PM   #3
Joemomma1
Joemomma1's Avatar
Peep it out yo.
http://67-72chevytrucks.com/vboard/s...d.php?t=209956
Joemomma1 is offline   Reply With Quote
Old 04-21-2009, 04:17 PM   #4
Joemomma1
Joemomma1's Avatar
You will find almost anything in these forums if you search. Chances are if you doing it now, someone here has already been down that road.
Whats up w/ the edit feature?
Old 04-21-2009, 04:20 PM   #5
65fleet
65fleet's Avatar
ok im limited on tools as far as removing coil springs and such , is the cross member swap possible? it just looks easier for some reason. thanks for the help
Old 04-21-2009, 04:22 PM   #6
Joemomma1
Joemomma1's Avatar
You should be able to. I think someone here w/ a 60 or 61 apache did it. How do you plan on swaping stuff if you dont have the right tools?
Ahh, here it is.
You really should seach.
http://67-72chevytrucks.com/vboard/s...d.php?t=335926
Old 04-21-2009, 04:32 PM   #7
65fleet
65fleet's Avatar
thanks for the link found someone else who did it too... ive got tools just not a spring compressor... thanks for the help!!! oh and your very right,,, the search feature on here is very helpful! thanks again!
Old 04-21-2009, 05:11 PM   #8
protrash64
Resistance is Futile
protrash64's Avatar
You dont need a spring compressor. Jack up the front, set it on stands. Put your jack under the lower control arm. Loosen your castle nuts, DO NOT REMOVE, and wack that spindle with a hand sledge...They pop right apart generally. Then remove your castle nut and slowly and carefully lower the jack until you can pop out the spring. It straight forward, but its work, no doubt.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
