Old 04-21-2009, 04:31 PM   #1
vectorit
What?
vectorit's Avatar
68 Transfer case mount help
I am trying to install my mounting bracket from the xfer case to the frame, and I am having trouble making sure it is right. Does anyone have a good picture of how their mount is set up, just as long as it is just like mine (stock). Oh, and my xfer case is the original T-221 Rockwell.
I tried putting it together according to the assembly manual I have, but it won't go together with the bracket on the frame. It's like the rubber and the single dual hole washer is to thick? Plus, mine originally had two very large washers and they are not depicted in the manual?
Any help would be greatly appreciated!
Thanks,
Chris
Chris
1968 K20 Suburban
1972 K10 LWB PU
vectorit is offline   Reply With Quote
Old 04-21-2009, 04:55 PM   #2
superchevy
Got big-block?
superchevy's Avatar
Re: 68 Transfer case mount help
Don't know if it's much help, but I just installed my transfer case...used a new set of bushings/sleeves from Energy Suspension...I pressed the new bushings into the bracket by hand...loosely bolted the bracket to the frame so I could slide things around a bit to get it lined up...had to manuever the t-case around a bit as well...got the t-case bolts started, then went to tightening everything up.
Casey
'68 CST SWB factory 396/T400
buddy buckets, a/c, ps, pb
'72 Corvette convertible 454/4spd/ac, ps, pb
'73 GMC Sierra Grande short wide 454/T400 ps, pb, ac
'77 K5 Blazer black on red, 350/T350/NP205 ps, pb, ac all original
'78 GMC Sierra Classic short wide 454/T400 ps, pb, ac
'72 GMC Sprint SP454. 1 of 38 built.
'73 GMC Sprint SP454. 1 of 71 built.
'75 GMC Sprint SP454. 1 of 25 built.
SOLD! '72 GMC K25 4x4 468/4L80e/NP205
build thread
http://67-72chevytrucks.com/vboard/s...23#post4324423
SOLD!'55 Chevy gasser 496/4spd
build thread
http://67-72chevytrucks.com/vboard/s...96#post4324396
superchevy is offline   Reply With Quote
Old 04-21-2009, 08:32 PM   #3
vectorit
What?
vectorit's Avatar
Yea, I got a pry bar and persuaded the bolt holes to line up on the xfer case bracket. But, the frame side bracket holes dont line up - yet. I am gonna let it sit like that for a while and see if the rubber compresses a little more in order for the holes to line up.
Chris
1968 K20 Suburban
1972 K10 LWB PU
Old 04-23-2009, 09:17 AM   #4
Yukon Jack
Post Whore
Yukon Jack's Avatar
Here are a couple pics of how my Rockwell mount was positioned
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
