Old 04-21-2009, 10:48 PM   #1
El_Crnicero
El_Crnicero's Avatar
oil Pan 350
Hey all,
Is it possible to remove the oil pan on a 71 c-10 350 without lifting the motor? Its all stock and I need to replace the gasket but there is not enough room to do a good job. My pops has a picker but I'll have to wait til the weekend if i do have to lift it.
Thanks.
Pablo
El_Crnicero is offline   Reply With Quote
Old 04-21-2009, 10:51 PM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: oil Pan 350
I'm not sure about lifting the engine but I know it will give you more clearance on the crankshaft if the timing mark is at 6 o'clock.
LockDoc
Leon
Old 04-21-2009, 11:01 PM   #3
hgs_notes
GEARHEAD
hgs_notes's Avatar
Re: oil Pan 350
You will have to lift the engine, but you can use a jack under the harmonic balancer and just undo the motor mount bolts. Keep an eye on where hte distributor hits the firewall.
If you don't have to remove the pan completely, there will be plenty of room. But cleaning off old hard gaskets while it's hanging there is not easy. Good luck.
hgs_notes is offline   Reply With Quote
Old 04-22-2009, 12:52 AM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: oil Pan 350
if you have access to an engine hoist... then do it that way. You'll be better off.
Old 04-22-2009, 01:18 AM   #5
El_Crnicero
Re: oil Pan 350
thanks guys, I guess I'll probably wait till I get to use my dad's cherry picker.
Too bad I guess I'll have to move to another part of the truck till this weekend.
Thanks for your help
P
Old 04-22-2009, 01:31 AM   #6
jbristo67
resident oilfield trash
jbristo67's Avatar
Re: oil Pan 350
Well if your going to do that then just pull it and rebuild it
1967 SWB C10 396/400 factory air
factory tach (sadly had to send to a new home)
1986 Honda 70 Fourtrax
1991 Chevrolet K5 blazer 2wd
1982 Mastercraft Pro Star 190 Stars and Stripes
2002 Chevrolet Tahoe
2011 Nissan Armada
jbristo67 is offline   Reply With Quote
Old 04-22-2009, 03:48 AM   #7
Irishpilot
Re: oil Pan 350
...as you can see, it's a sickness we all have; why just replace a part when we can rebuild the whole truck! I suffer from this affliction just as much as the next guy...
1971 C-10, 406ci, restoration begun!
406ci sb; zero decked, bored .030, edelbrock aluminum e-tec heads, edelbrock performer RPM intake, comp 268 cam, comp 1.6 pro-magnum roller rockers, MSD street fire HEI, MSD 8.5mm wires, Holley Street demon 770, Hedman LT headers. 10.6:1 compression, Air Ride Tech bags on all 4-corners.
Irishpilot is offline   Reply With Quote
Old 04-22-2009, 06:08 AM   #8
Longhorn Man
Re: oil Pan 350
lets just stick to an oil pan gasket.
Old 04-22-2009, 07:01 AM   #9
Sport/Truck
Sierra Grande Club
Sport/Truck's Avatar
Re: oil Pan 350
Seems like thats how it started with me, 2 years ago.
s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe.
Sport/Truck is offline   Reply With Quote
Old 04-23-2009, 12:25 AM   #10
El_Crnicero
Re: oil Pan 350
LOL,
That how I got in this mess, I had a stuck float on my quadrapuke, but I also had some better parts awaiting, new cam, edelbrock performer intake, camel hump heads, new lifters, hardened rods, nice acell distributer, and a nice coil.
All from a donor car, my V8 vega gt that got crushed by a tree.
So bad carb, why not redo the whole deal.....
Oh yeah and while I'm at it lets finish shaving the turn signal markers and badges too. The list is a monster!
P
