Old 12-26-2002, 12:45 AM   #1
Reumster
L.E.D. Freak
Reumster's Avatar
20's and tire size for front. Diameter?s
What is the maximum outside diameter of a 20" tire you can run with say a 4/6 drop in the front? I was looking at 275/45/20s
The outside diameter of these is 29.8"
I want to run all 4 tires the same size.
Specializing in Custom L.E.D. inserts.
http://www.ccled.com/
Contact me @ blazer2wd1972@hotmail.com
(406)675-8082
or Joel @ jmcwaters@eps-corp.net
1972 2wd Blazer, 350/700R4/3:73 posi, err & Custom L.E.D. inserts! LOL
Reumster is offline   Reply With Quote
Old 12-26-2002, 01:35 AM   #2
Alexis
Member since 2000
Alexis's Avatar
two very helpfull links, i'm doing the same lookin for the same size tire to run all around ot just try to wide tire in the rear without effecting side wall hieght.
http://www.miata.net/garage/tirecalc.html
http://www.powerdog.com/tiresize.cgi
hope it help
Alexis is offline   Reply With Quote
Old 12-26-2002, 04:48 AM   #3
big.l.a
big.l.a's Avatar
Tire Size
You should be O.K. as long as you front Rims are 8's
you can run up to a 10 rim In the rear and be O.K.
71 C10 LWB With
Edelbrock 7101& 1406 Carb
Accel HEI Blue Print
Accel 8.8 Wires
Soon to have possi &
186 Camel hump heads
Dropped 2-1/2F&4R
Dynomax Headers
Duals Flowtech Aftburners
Tonneau Cover Frm 89 F150
79 Monte C
big.l.a is offline   Reply With Quote
Old 12-26-2002, 02:15 PM   #4
Reumster
L.E.D. Freak
Reumster's Avatar
I plan on running 4 20"X8.5" KMC stealths. And the 275/45/20s all round. I just don't want to run into clearance problems up front.
(406)675-8082
