Problem after removing voltage regulator!
Hey everyone, I encountered a problem after doing the voltage regulator elimination procedure. I wired my '72 chevy truck exactly how the post about eliminating the regulator stated. When I started the truck after doing this I was getting 17 volts at the battery, normal?? When I went to start the truck the next day the battery was dead. Any suggestions on where I should start checking!! Thanks in advance for the help!!
It's alsways something.....
![]() Join Date: Nov 2008
Re: Problem after removing voltage regulator!
[ where I should start checking!! [/QUOTE]
Go out and turn off the lights! JK, JK, JK I just pasted this info from the FAQ page.- it should help-FAQ page has TONS of same kind of info is you havent seen it |
you say you eliminated your regulator, I assume you replaced your alternator with an internal regulator and so 17 volts may be on the high side but I think you should be ok. Normal would be 14-16 or even 17 when running. If your battery was run down and the alternator was trying to charge it, making for more of a load on the alternator, it would not surprise me to see 17 volts.
1970 K20, 350--- SOLD 05 silverado extended cab short box- duramax Jeep wrangler unlimited |
17 volts will burn out your lights, radio, & any sensitive electrical assesories besides ruining the battery. 14-14.5 is max. If you eliminated the voltage reg. you have to use an internal reg. alt. If you did change the alt. it is wired wrong or has a bad internal regulator.
Interesting, my truck runs 15 to 15.5 all the time and have never had a problem. I must be lucky.
Chemist under the hood...
Definitely needs a regulator-Should not run that high. What is it with the head lights on?
Current fleet: 2013 GMC Sierra, 5.3L, 4x4 1988 GMC Sierra, 305, Auto 1984 Jeep Grand Wagoneer, 360 V8 1997 VW Cabrio, 2.0L 2017 Toyota Rav4, 2.5L Stuff I wish I still had: 2013 Toyota Matrix [RIP] 1967 GMC 910 Fleetside, 283 V8 [1st Love-SOLD] 1987 Jeep Cherokee Laredo 4X4, 4.0 I-6 [SOLD} 1994 Chevrolet Caprice Classic, 5.7LV8 [SOLD] 1995 Chevrolet Astro AWD, 4.3L V6 (RIP) 1998 Chevrolet Suburban 4x4, 5.7L V8 [SOLD] |
#8 | |
Middle-aged Curmudgeon
Bret Check out the site's Truck Tech FAQ. Be a site supporter. My more-or-less pathetic build thread. Board members I've met: ------------------------------ Longhorn Man Dieselwrencher jholley big mike71 |
Internal regulator may be bad....with truck off, key off and connector pulled off the alternator I am reading 2 volts out of terminal 1 on alternator. This draw most likely drained my battery overnight. Is there a way to check the internal regulator??
![]() Join Date: Sep 2005
my f-150 runs 15 volts my chevy runs at the same
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
