Old 04-22-2009, 12:00 PM   #1
Sinister
Between Trucks...
Sinister's Avatar
Question Change cam with motor in truck?
Is it possible to change the cam with the motor in the truck? Do you have to pull the grill?
Beat it to fit,
Paint it to match...
Sinister is offline   Reply With Quote
Old 04-22-2009, 12:28 PM   #2
smoky02
Location: Sunny, Florida, some might call it South Alabama
Re: Change cam with motor in truck?
I have been told that you can do it. And that you just pull the radiator and all the accesories on the front of the motor. But I am not sure if I believe that or not...LOL
Just sold my C10...sad day...
Looking for a 1972 Blazer to hopefully fill the hole in my heart.
smoky02 is offline   Reply With Quote
Old 04-22-2009, 12:59 PM   #3
Mthird
you have to remove the Headers or manifolds which ever you have, the intake the heads the radiator and all the accessories, the water pump, basically everything, use a magnet to get out the lifters. I recommend just yanking the motor.
71 Chevy Custom Deluxe 10
All original, although in need of some TLC.
only 3 owners, my grandpa, my dad, and me.
Mthird is offline   Reply With Quote
Old 04-22-2009, 01:03 PM   #4
EdB
I did this when I had a lobe wear down on
a new engine. It has been a few years. As I remember,
I had to pull the radiator, water pump, intake and timing
chain cover. I had to pull the lifters and the new cam
went in ok. Something to consider is the age of the
engine and wear on the cam bearings. Cleanness is
critical. Go easy to avoid damaging the bearings.
EdB
EdB is offline   Reply With Quote
Old 04-22-2009, 01:07 PM   #5
Jim_PA
Why do you remove heads and headers? I can't recall doing this when I swapped a cam in my 84 Camaro some ago...
Jim_PA is offline   Reply With Quote
Old 04-22-2009, 02:28 PM   #6
long69
no you dont have to remove headers and heads to change the cam in or out of the truck. as far as the grill may be a tape measure would be the best way to check. the cam is just about as long as the block, if you have enough to stick another engine in front of your present one then you can leave the grill.
long69 is offline   Reply With Quote
Old 04-22-2009, 02:59 PM   #7
monte0185
monte0185's Avatar
IT can be done. Its not fun but it can be done.
A computer once beat me at chess, but it was no match for me at kick boxing.
Duct tape is like the force. It has a light side, a dark side, and it holds the world together.
monte0185 is offline   Reply With Quote
Old 04-22-2009, 04:28 PM   #8
So.Cal.Super
It'll Buff Out!
So.Cal.Super's Avatar
I just did mine this weekend with the motor in the truck. I will try and give you an idea of how it went.
I pumped down the A/C
Disconnect the battery
Drained the coolant
Aired down the front tires
(I have 33’s so this makes it easier to work on this project)
Removed the egg crate (I left my grill in)
Removed the radiator
Removed the condenser
Removed the center support
Removed the belts
Removed the Fan clutch
Removed the water pump
Removed the Dampener pulley
Removed the timing chain cover
Check for TDC (I pulled my plugs since I was going to change them)
Removed the dizzy
Removed the Carb
Removed the intake
Removed the valve covers
Loosened the lifters and removed the pushrods.
( I like to keep left bank separate from right and I also checked to make sure I had no bent ones.)
Removed lifters with magnet
Unbolt fuel pump and let the rod drop out of the cam’s way
Removed the Cam
(Screw in a few bolts that fit so you can get a grip on it gently wiggle and pull like you were delivering your first born son. If it’s stubborn give him a few togs. but, be careful of the bearings.
You don’t want to have to beat it out with a hammer or you will have/already have other serious problems.)
You can inspect your cam bearings at this time (what you can see of them) if you see any broken or cracked I would stop until you can pull the motor.
Cover lifter valley with rags remove large chunks of gasket by hand, scrape off remaining.
REMOVE RAGS
Clean up the timing chain area. I trimmed my oil pan gasket back to flush.
Inspect new cam then lube, lube again and lube some more.
Slowly walk it, wiggle it and walk it back into place.
Lube up your lifters with cam lube.
And reinstall timing gear.
From here it just putting everything back on, new seals, gaskets, etc.
This is a write up of how what I did with the engine in the truck. I am sure every one does it their own way. I started this project because I had a lifter ticking and my dampener pulley slipped so I couldn't set proper timing. I know the rest of the motor is in good shape from an earlier tear down.
What I was asked from when I was calling vendors about my cam.
(This may help or you may already know this.)
I told them I wanted to use stock push rods and valve springs.
They wanted to know if my valve springs were still good
I knew they were from an earlier tear down
So that set the parameters for what Cam’s I could use and since I was tearing it all apart I put a new timing gear in it, new water pump and new intake. I wish I would have taken step by step pictures but I am working on it at my buddies since he has all the pullers and odd tools I don’t have. Also don’t forget to use a break in lube and good oil (I used Valvoline VR 20-50(high zinc) and follow the cam specs for break in (mine is 2500 rpm for ½ hour)
This is by no means meant to be a guide more my point of view of what I did and how it can be done in the truck.
Good luck.
I am finishing mine hopefully this weekend I do have before and after pics and will post them then.
"Instructions are just another mans opinion"
Become a Supporting Member
Man Card Rules
http://67-72chevytrucks.com/vboard/s...d.php?t=634550
72 Chevy Cheyenne Super 400 LWB
So.Cal.Super is offline   Reply With Quote
Old 04-22-2009, 05:32 PM   #9
bowtiedude
bowtiedude's Avatar
I have done the in truck swap on many of these trucks. You do not have to take the grille out.
'96 K2500 GMC 6.5 4L80E
'88 c1500 RCSB lowered 4 & 6 454 TH700R4 (still being built)
'79 K20 Chevy 400 4 spd
'69 K20 Chevy 406 4spd
'70 K10 Chevy 355 4spd 6 inch lift
'70 C-20 (son's truck) originally 292 4spd now a 350 4spd
Hey I didn't even want to until you told me I couldn't !
bowtiedude is offline   Reply With Quote
Old 04-22-2009, 05:51 PM   #10
Sinister
Between Trucks...
Sinister's Avatar
Cool, thanks guys.
Beat it to fit,
Old 04-22-2009, 06:04 PM   #11
eightbanger
454 MAKES IT ROAR
eightbanger's Avatar
Good luck.
Nice walkthrough SO.Cal...Thanks for that.
Nigel.
An American living in a British body.
1971 Chevy Cheyenne 10 454
"In a time of universal deceit, telling the truth becomes a revolutionary act." - George Orwell
"When injustice becomes law, resistance becomes duty" - Thomas Jefferson
No more pain.
03.12.60 -- 12.28.10
http://www.youtube.com/Eightbanger
eightbanger is offline   Reply With Quote
Old 04-23-2009, 03:01 AM   #12
So.Cal.Super
It'll Buff Out!
Thanks! I just wish I would have taken pic's now I am kicking myself for not getting every step
Ah we live and learn.
Man Card Rules
Old 04-23-2009, 06:29 AM   #13
Ol'Rover
Project: years too late.
Ol'Rover's Avatar
my dad used to change out cams in his truck in an hour, befor he had to go home from work lol. He didnt pull the motor, so it can be done.
Just the rad, some people pull the grill just to be safe, but there should be enough room from the front of the block to the grill, to get the old cam out and the new one in. As far as i know all you realy need to take off is : Waterpump, any other front end components in the way, and move the rad.
1971 C10 Stepper LSX 5.3/4L60E 3.73 12bolt posi. Father Son Project. In Memory of Bruce C. Shorten. Rest easy Dad. Ill take it fryom here.
Ol'Rover is offline   Reply With Quote
Old 04-23-2009, 07:49 AM   #14
Sinister
Between Trucks...
Sinister's Avatar
Drained the coolant
Removed the belts
Removed the dizzy
Removed the Carb
Removed the intake
Removed the Cam
REMOVE RAGS
Good luck.
Should be a FAQ.
Beat it to fit,
Old 04-23-2009, 07:52 AM   #15
primered_junk
ASE master tech/machinist
primered_junk's Avatar
Also don't forget one key factor. Only lube the bottom side of the lifters, DON'T lube the sides, they will not rotate in the lifter bores and flatten the lobes on your new cam.
"I sit here and I pray in my broken down Chevrolet....."
primered_junk is offline   Reply With Quote
Old 04-23-2009, 10:19 AM   #16
hchad18
hchad18's Avatar
You had to say that. I just installed my cam and lifters and put a ring of lube around the bottom of the lifter sides, AND put the intake on already.
hchad18 is offline   Reply With Quote
Old 04-23-2009, 10:48 AM   #17
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Isn't the lube for protection upon initial startup -- and won't it be washed off by normal oil flow in a reasonable amount of time as the engine runs, therefore allowing the lifters to rotate as normal?
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is offline   Reply With Quote
Old 04-23-2009, 11:03 AM   #18
hchad18
hchad18's Avatar
Everywhere I've read says lube bottom side of lifter. The vortec intake gasket is $30.00. I hate to have to buy a new one.
Old 04-23-2009, 11:40 AM   #19
So.Cal.Super
It'll Buff Out!
I have never heard this before but I can say that about a lot of things. I just called edelbrock tech to ask them since I have always coated my lifters during a swap out.... on hold with tech now.
Man Card Rules
Old 04-23-2009, 11:58 AM   #20
Sinister
Between Trucks...
Sinister's Avatar
In "How to Build the Smallblock Chevrolet", it says breakin lube on the cam contact surface of the lifter and assembly lube on the outside of the lifter.
Beat it to fit,
Old 04-23-2009, 12:07 PM   #21
So.Cal.Super
It'll Buff Out!
According to Edelbrock tech this will not cause lobe wear. Chris who I spoke with and he double checked with a few others while I was on hold for quite a few mins. They all agreed this would not cause a problem. What would cause a problem was if the bottom of the lifters were not coated at all. But coating the sides with assembly lube just insures some lubrication during start up to prevent wear.
This is how I have always done my cam change outs (probably half a dozen with friends and all) and have never had a problem.
And since this is who is warranting my cam I will go with they tell me.
Man Card Rules
Old 04-23-2009, 12:10 PM   #22
So.Cal.Super
It'll Buff Out!
You posted while I was on hold Sinister but, Yeah thats how I've done it / seen it done. I also know I have seen a fair share of "I have never had that happen before" problems to know the strangest thing can happen.
Man Card Rules
Old 04-23-2009, 12:27 PM   #23
americanmusc1e
americanmusc1e's Avatar
if you have the plasic gaskets with O-rings, they should be reusable. if not, get 'em they work great
-- Josh
Instagram: @americanmusc1e
OLD SKOOL-- 1970 C10. 454/Th400/3.07 posi Build Thread
FARM TRUCK----1949 Chevrolet 3800 Power Wagon Hauler Build Thread
1999 4wd OBS Tahoe - daily.
DM me if you can't see photos i posted
americanmusc1e is offline   Reply With Quote
