Old 04-22-2009, 03:03 PM   #1
smoky02
Location: Sunny, Florida, some might call it South Alabama
Gear Ratio and Carrier
I am about to start upgrading a few things on my truck. I thought maybe a few people on here would be able to give me some advice as to whether I should go with a 4:10 or 3:73 gears. I am running 700R4 and don't usually do a lot of top end driving, most of the time she stays around 40 or 50, but on occasion I do drive to bama or take the truck on road trips. At 80 MPH I'm doing 2,000 RPM's. Also my rear end came out of a 71 or 72 (or so I was told) how do I find out if it's a series 3 or series 4 housing?
Just sold my C10...sad day...
Looking for a 1972 Blazer to hopefully fill the hole in my heart.
smoky02 is offline   Reply With Quote
Old 04-22-2009, 04:25 PM   #2
smoky02
Re: Gear Ratio and Carrier
Really no one?
Old 04-22-2009, 04:43 PM   #3
So.Cal.Super
It'll Buff Out!
So.Cal.Super's Avatar
see if this helps
http://www.coloradok5.com/axleguide.shtml
hope it does
"Instructions are just another mans opinion"
Become a Supporting Member
Man Card Rules
http://67-72chevytrucks.com/vboard/s...d.php?t=634550
72 Chevy Cheyenne Super 400 LWB
So.Cal.Super is offline   Reply With Quote
Old 04-22-2009, 04:47 PM   #4
john
member #16
john's Avatar
Most of the trucks are running 3:73.1 with a 700r4. I think your converter might be fouling up your readings.A 700r4 with a .70 overdrive would need a 2:73.1 ratio for 80 mph at 2000 rpm.
john is offline   Reply With Quote
Old 04-22-2009, 04:47 PM   #5
So.Cal.Super
It'll Buff Out!
this might help you figure out what rpm you would see
http://www.ringpinion.com/Calc_RPM.aspx
Man Card Rules
Old 04-22-2009, 04:53 PM   #6
MrC1
Dork For Days
MrC1's Avatar
Would need to know more info.
Tire diameter?
What type rear do you have (fat is not a good answer)?
What ratio do you have now? This will also tell you what carrier you have!
You don't need quite as much rear gear with a 700R4 as with other transmssions since 1st gear is pretty steep. It really depends what you use the truck for. If you do truck duty (hauling, towing, etc.) I would suggest going with as much gear as you canhandle while keeping your cruising RPM in an acceptable range.
1972 C20, 402/700R4 - My first classic truck, bought in September 2005. 85% transformed from "Farm" to "Cool" status!
1970 Dodge Challenger 440, 4sp (my other toy) 12.67 @ 117 MPH, with a pathetic 2.022 60'
2007 Dodge Charger SRT-8
2008 Cadillac CTS
All-American garage, baby!
MrC1 is offline   Reply With Quote
Old 04-22-2009, 05:21 PM   #7
smoky02
My speedo is more than likely off, but I know it reads slow. Right now I have 3:08 gears. My tires are 285/55R18. I will check out that site ya'll mentioned, thank you
Old 04-22-2009, 09:05 PM   #8
Mike C
Mike C's Avatar
Your tires are approximately 30" tall. (285/25.4=11.2" 11.2*.55=6.17" sidewall height *2+18=30.344) Stock tires were approximately 28 tall. That is why your speedo is off. 2*pi*r for your new tire is 94" while the OEM tire would be 88". The new tire rolls 6" further for every rev or 7% which will be approximately what your speedo is off. Assuming the 3.08 is your original gear.
The 3.08 is a 3 series carrier which would be good up to 3.55 gears. 3.73 and up would be 4 series, in a truck. Different break point on gears in cars.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 04-23-2009, 06:52 AM   #9
smoky02
So that means that if I want to run a gear higher than 3.55 I would have to change out my entire rear end? Or can you buy 4.10s for a series 3 rear end?
Old 04-23-2009, 08:10 AM   #10
texnician01
texnician01's Avatar
Smokey, you will need to either find a series 4 carrier if you want to use 4.10 gears or buy a set of thick gears (very common) for use on your series 3 carrier. I think I may have an open series 4 but I would have to look, if you are interested. I've never used a thick set of gears but I have to wonder about strengh, does putting that thicker gear in, moving the force away from the flange add extra stress? Anyone ever used a set of these gears. You can get thick gears about anywhere you can get normal gears, a quick search led me to several places to get them but they are about $50 higher because of the extra metal.
Good luck
69 C-10, 340HP 327
55 chevy 4 door 150
47 Willys CJ-2A
05 Harley Night Train
06 1200 Sportster (Wife's bike)
70 Honda CL350
OIF2 & OIF7 Veteran
Nathan & Tiffany
texnician01 is offline   Reply With Quote
Old 04-23-2009, 08:28 AM   #11
texnician01
Just noticed you have a posi, the best thing then will most likely be the thick gears. When I was looking for a posi it proved to be quite a daunting task, people either didn't want to part with them or they didn't have any.
Also, you will not have to change the whole rearend, just the carrier. The housings and axles are all the same except for length. Your truck would have originally had a narrow axle, the 70 and up trucks had an axle 1 1/2 inches wider, 3/4 on each side. The carriers are interchangeable for any truck 12 bolt and they used them up into the 80's. When changing a carrier and gears, it's not a bad time to rebuild the whole rearend with minimal extra cost.
69 C-10, 340HP 327
55 chevy 4 door 150
47 Willys CJ-2A
70 Honda CL350
OIF2 & OIF7 Veteran
Nathan & Tiffany
Old 04-23-2009, 08:28 AM   #12
smoky02
Alright, thank you, I am going to do some checking around about the thicker gears. She isn't going to be a track truck, just my toy to drive when I feel like playing. And also it seems a waste and have to take out a posi, just to buy another posi.
Old 04-23-2009, 08:30 AM   #13
smoky02
Also the rear end that I have came from a 71, so it wouldn't be the narrower one correct?
Old 04-23-2009, 08:34 AM   #14
texnician01
Correct, yours should be a wide rear, that won't ever matter unless you have to replace a housing or axle.
69 C-10, 340HP 327
55 chevy 4 door 150
47 Willys CJ-2A
70 Honda CL350
OIF2 & OIF7 Veteran
Nathan & Tiffany
Old 04-23-2009, 08:40 AM   #15
smoky02
cool, thanks for ur help
Old 04-23-2009, 08:50 AM   #16
faribran
Morning bud
pap
faribran is offline   Reply With Quote
Old 04-23-2009, 08:57 AM   #17
smoky02
LOL...hey pap, the week is almost over...any luck on finding your shift linkage?
Old 04-23-2009, 11:54 AM   #18
smoky02
Called summit, jegs, and also called motive gear, and they set me up with the best deal on ring and pinion and a bearing set. The shop that is supposed to install the gears for me told me that motive is a good name, and just wanted to check with you guys and see if anyone is running gears from them? Also I'm going with the 4.10s
