04-22-2009, 03:10 PM | #1 |
Fuel lines for a 70
I have never made fuel lines before, and haven't found a good source for repro ones, so it looks like I may get to try my hands out at bending some.
I am looking at getting this from Summit: http://store.summitracing.com/partde...5&autoview=sku But how to I connect it up with the stock sending unit and stock mechanical fuel pump? Do I need to flare the ends and then use some rubber sections and hose clams to connect them, or are there fittings that need to be purchased? Also, where is the best place to run them under the blazer? Thanks.
1970 Blazer 350/SM465/205 SOLD! | 1998 Z3 |
04-23-2009, 08:10 AM | #2 |
Re: Fuel lines for a 70
I have replaced the fuel lines on my 70 Blazer although I haven't fired it up yet. I used some from Inline Tube at inlinetube.com and they matched up great. You will have to use some rubber fuel lines to marry up the ends from the fuel tank and to the pump.
