05-16-2002, 03:15 PM | #1 |
Speedometer
My speedometer has stop working. Is there a way to repair it or do I have to find another one. I have checked the cable and it is working fine it is just the mileage meter. My mileage is at 73,000 and I would like to stay right there because it is the original miles. Any suggestions
Thanks Drew67
DREW67 |
05-16-2002, 03:29 PM | #2 |
if you've verified that the cable is turning ok, I suppose you could have the speedo looked at, not sure how repairable they are, but I'm sure the cost will be more than just replacing it...maybe put another one in while it's being looked at..??
------------------ '72 short step, 350, 700R4, tilt, ps, pdb, a/c, lowered coils, etc., other work in progress... San Diego, CA http://www.ixpres.com/vlusardi/chevtrk.htm
'72 short step, 350, 700R4, tilt, ps, pdb, a/c, lowered coils, etc., other work in progress... San Diego, CA 72 Stepside Project |
05-16-2002, 03:32 PM | #3 |
If all else fails, you should be able to pick another one up at a swap meet relatively cheap. Then, take you a hand drill and spin the speedo until the mileage matches your original one.
------------------ "Fast Orange" 1972 Chevy Stepside that will one day be finished!!
Randy aka "Fast Orange" 1972 Chevy Stepside that will one day be finished!! |
05-16-2002, 08:16 PM | #4 |
its all about the +6 inches
I tried the drill thing, only ran it like 34 MPH or something...not fast enough to make it worth the time.
I wouldn't go to the swap meat...I'd check the junk yards first. ------------------ '69 G.M.C. 350/350. Trying to clean up the left over damage from the Dope-Smokin-Old-Man I've been dubbed the Longhorn Freak/Fanatic/Expert, I just hope I can live up to it. FINALLY got the HORNIAC...a '70 one ton Longhorn with a Pontiac 350/350 and lots of 'personality'. Check out The Longhorn Webite. E-mail longhornmail@yahoo.com My name is Andy...not Randy...I'm in Ohio...Not Illinois...close enough? Columbus Ohio |
05-16-2002, 09:02 PM | #5 |
you can also pull the whole dial and turn the numbers where you need them. should only be 2 screws on the face of the speedo.
69-C10 LWB 71- fleetside shortbed It's a shame stupidity isn't painful Never play leapfrog with a unicorn |
05-16-2002, 10:23 PM | #6 |
Old member
I have worked on a couple of these and you can take it apart and change the milage by hand, but you will have to find a small peice of card board to hold the pins in place afterward so the odometer will work without always being in the middle of the numbers.
------------------ Andy 71's Are for ever!!! or 67,68,69,70,72 71,factory tach,tilt for straight drive,gauges,ac,speed warning,clock,305 HO TPI with 700-R4, lowered 2" & 3" ,and 17" Chrome Stealth wheels, Pioneer reciever,100 watt amp, 6 disc changer, 2-10" subs (behind seat) 2-6x9 in doors, 2-3ways mounted under seat, and 2 tweaters on door panels www.geocities.com/chevy71tpi/main.html www.picturetrail.com/Andy4639
