Old 04-22-2009, 03:49 PM   #1
jwa76fleetside
jwa76fleetside's Avatar
question about my 76
I have this 91 k5 and its fuel injected. Should i yank the fuel injection off of it somehow to try to install on my 76? would this even work? anything else i should grab before sending to the junkyard
76 Chevy Fleetside
63 Lincoln Continental w/ Ford Racing 460 (550hp)
2012 VW GTI
2013 Escalade
2008 Harley
jwa76fleetside is offline   Reply With Quote
Old 04-22-2009, 04:05 PM   #2
87c10slammer
truck addict
Re: question about my 76
if you grab the motor, fuel system, pump, wiring harness, and ecu... you could make it work fairly easy... the only thing i would be worried about is getting the tranny too.... im not exactly sure when they switched over to the electronic shift trannys but i researched doing the complete oposite... i wanted to gut my 00 jimmy 4.3 and put in an old 350... the only thing that stopped me was the fact that it would be a pita to get the tranny to work right
trucks
87c10slammer is offline   Reply With Quote
Old 04-22-2009, 04:53 PM   #3
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
Electronic trans started in 1993. If the 76 is a 4x4 you can get the whole drivetrain, otherwise you would have to pull the trans down and replace the output shaft and get a tail housing for it to work. Engine should swap fine if you get all the electricals with it.
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 04-22-2009, 04:59 PM   #4
jwa76fleetside
ooh too much effort for not enough reward. Maybe down the line i will just buy an EFI set up to replace the intake and carb. Carb is functioning perfectly well for me right now though so no hurry.
76 Chevy Fleetside
2012 VW GTI
2013 Escalade
2008 Harley
Old 04-22-2009, 05:01 PM   #5
jwa76fleetside
these are pretty slick
http://www.mass-floefi.com/
76 Chevy Fleetside
2012 VW GTI
2013 Escalade
2008 Harley
