Old 04-22-2009, 05:26 PM   #1
Pulcher01
94 Chevy Lift kit 6 inch
Hey guys I'm new to this site and was wondering if anybody knows where I could maybe find a used kit. I have a 94 chevy silverado ext cab. I am trying to restore this truck into something I'm proud of. I dont have a lot of money since I'm trying to fix the body and do the lift and wheel thing. Any help would be great. Thanks Bobby.
Pulcher01 is offline   Reply With Quote
Old 04-22-2009, 06:37 PM   #2
dammitmitchell
the pollock
dammitmitchell's Avatar
Re: 94 Chevy Lift kit 6 inch
wow! restore a 96?
that makes me feel old!
he he he
like my daughter said the other day. "dadd 1990 was like forever ago"
ewwwww...
wll dude for finding a used kit you can look thorugh the parts forums here or you can search your local classified.. or craigslist..
good luck
Jack of ALL trades, Master of none.. (but one... procrastination)
Army vet 02-08
RIP El Jay! Miss you brother!
http://67-72chevytrucks.com/vboard/s...d.php?t=343538
http://67-72chevytrucks.com/vboard/s...d.php?t=386042
dammitmitchell is offline   Reply With Quote
Old 04-22-2009, 07:24 PM   #3
Pulcher01
Yah I have pretty much looked everywhere. If somebody has one to sell they are wanting almost as much as a new one.
Old 04-23-2009, 09:33 PM   #4
rockn30809
Check fullsizechevy.com, they pop up on there sometimes. Also check out the rough counrty lifts. They are around $900.00 new and a pretty decent lift.
rockn30809 is offline   Reply With Quote
Old 04-24-2009, 12:40 AM   #5
dammitmitchell
the pollock
you can also peice together your lift over time..
like say buy a pair of fronts.. then shocks.. then rears... and shocks.. then in the future for like your birthday poly EVERYTHING...
see..
but in the end it ends up being mroe expensive...
which sucks..
well maby you'll luck out
you can always go cheap and spring your front and then block your rear...
Army vet 02-08
Old 04-24-2009, 11:13 PM   #6
Pulcher01
I was also thinking the same thing but I'm not sure what all I would need for a complete kit.
Old 04-25-2009, 12:53 AM   #7
dammitmitchell
the pollock
http://www.roughcountry.com/chevy_4wd_88-98_6.html
the only thing i would add to it is the "steering stabalizer" trust me it helps alot..
and it REALLLY sucks when the powersteering goes out..
you build muscle fast like that..
and here's another link
http://www.stylintrucks.com/part.asp...4&scid=FROOGLE
you can sell your first born son and buy that it =-)
good luck
Army vet 02-08
Old 04-25-2009, 12:53 AM   #8
dammitmitchell
the pollock
p.s. someone here with a newer truck will even tually chime in and tell you exactly what you need to know
Army vet 02-08
Old 04-25-2009, 12:59 AM   #9
Pulcher01
Thanks dammitmitchell for the advise. If I did block the rear what is the differance between shock and block?
Old 04-25-2009, 01:52 AM   #10
dammitmitchell
the pollock
wheeew... first difference is money
blcosk are cheap and do not change the load capacity of the rear leafs....
if you want all "suspension" lift like i did.. you pay a little more so that your rear springs have a more dramatic arch and are longer....
now the other option is also an "add a leaf" which increases the load capacity of the springs by adding a single (one at a time) short thicker leaf spring
so.. block, add a leaf, then to full leafs
that's the order cheapest to most costly...
of you want to just mud and have fun, do your front up with a kit.. and then block your rear with the kit (included all in that first kit link i sent you)
now if you plan on towing with that truck..
you can do a shorter block lift and then add a leaf to that..
or you can do a full leaf spring lift with your towing capacity in mind...
and remember a add a leaf stiffens the hell out of your suspension..
and if my views are skewed in any way please let me know (this is to all of yas )
Army vet 02-08
Old 04-25-2009, 01:53 AM   #11
dammitmitchell
the pollock
i also stumbled across this
http://ezinearticles.com/?A-Beginner...Kits&id=533733
Army vet 02-08
Old 04-25-2009, 02:55 AM   #12
Pulcher01
Thanks dammitmitchell. My plans for the truck is really not to off road it but to drive it around. It will be my daily driver so thats why I was wondering about the block method. I dont want to beat myself to death. It just sucks looking for lifts and seeing older vehicles and the cost of those lifts are so much cheaper then the one I am needing. Looks like I'm going to have to suck it up and pay the extra $..
