Amateur rust repair
I bought a 1972 Jimmy about a month ago and it needed a little rust repair on the top rail of the bedside. Just thought I would show a few pics of what I did. Cut out the are, then cut it out bigger because of more rust than I thouight! I bought the repair piece from Teeitup last week.
Re: Amateur rust repair
Fitting the piece and letting my son do the weldiing.
Welding it in and grinding it down. I didn't use any bondo yet, I just wanted to fix that spot! Now I can concentrate on the drivetrain, I need the tranny rebuilt! Thanks to Randy(Teeitup) for the piece I needed it worked out perfrect.
Old School, New Style
Looks great. What other rust is hiding in there?
The Good: - 72 GMC Jimmy 4x4 - 307 cid / 350 th - 70 Chevy Suburban 1/2T 2wd - 454 cid /400 th - 96 Chevy Impala SS - mainly stock - 98 Chevy Tahoe LT 4x4 - all stock The Bad: - 86 Chevy Suburban 1/2T 4x4 - winter beater The Ugly: - 72 Chevy Suburban 1/2T 2wd - parts truck |
No other rust other than a little in the floor and back corner of doors. Thats all!
Rods
![]() Join Date: Nov 2002
you are better off not taping off your repair. when it comes to sanding that later it will give you issues. just let it overspray.
I'm a poor spectator
Good job, looks good.
2006 Jeep Unlimited IMPACT ORANGE 1993 Chevy 2500 4x4 ExCab LWB 454/NV4500 Tow rig ![]() 1977 Ford F100 2x4 LWB 1st truck I owned, still have it!!! ![]() 1979 Ford F150 4x4 SWB Built Ford Tough!!! ![]() 1971 Chevy Blazer 350 / SM465 / NP205 UNDER CONSTRUCTION Soon to have a LQ4 6.0!!! |
![]() Join Date: Dec 2008
Good Job, the hardest part is doing it...Contrary to what some people would have you believe, no one was an expert when they started, right?
I am not too worried about the edge from the tape as I will be going over the complete body at some point. I believe the reason the rust was in this spot is because there was a small dent right at the top of the bedside just under the top. I think this dent let water travel under the top and sit on the bed rail. I knew it was there when I bought it, but the truck was basically rust free everywhere else, this is not where you typically see rust on these things! Now all I need is a new tranny or rebuild mine.
Nice job looks reallygod
70 SWB STEPSIDE 70 BLAZER 09 challenger |
