04-22-2009, 08:16 PM | #1 |
Señor Member
71-72 front rotor hub dimensions
Anyone got a caliper handy and a wheel off their 71+ disc brake setup? I'm looking for the dimensions for the snout (including dust cap) to ensure a wheel with a center bore of 3.07" and hub depth of 2.75" will fit.
04-23-2009, 09:05 AM | #2 |
PROJECT 7DEUCE
Re: 71-72 front rotor hub dimensions
Hey ken if i caers I LL GET THE MEASUREMENT FOR YA..
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
04-25-2009, 03:15 AM | #3 |
PROJECT 7DEUCE
Ken it looks like my dog ate my calipers or someone walked off with them..
04-25-2009, 04:00 AM | #4 |
Señor Member
No problem on my end. But if your dog ate them, you're going to have problems in a few hours *gulp*
04-25-2009, 10:48 AM | #5 |
A guy with a truck
I have 3.06 and 1.75. You should be good. In return, I would like to know what kind of wheels you're gonna use.
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy Last edited by gringoloco; 04-25-2009 at 10:51 AM. |
04-25-2009, 11:00 AM | #6 |
67-72 parts collector,…
XXL,... I measured my blazer rotors. The hub diameter was about 3.030" and the depth was 2.875".
They are ECE cross-drilled 5 lug rotors and with new ECE dust caps. I also measured the bore of a 5 lug ralley. I came up with 3.035". Hope this helps.
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 04-25-2009 at 11:04 AM. |
04-25-2009, 11:05 AM | #7 |
A guy with a truck
Doh! Go with lolife's numbers. I just realized my loose rotors are 1" thick, so the bore would be the same but the snout is shorter- and I didn't include the dust cap...
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
04-25-2009, 11:35 AM | #8 |
My rotor are 1-1/4" thick, if that makes a difference.
04-25-2009, 01:19 PM | #9 |
Señor Member
Sounds like a worst case of the dreaded cap doesn't fit syndrome. Or best case, they work fine. I'll let you know on the wheel type once I get them... I need a head start on the crowd
04-25-2009, 03:02 PM | #10 |
A guy with a truck
Cap no-fit is easily curable with an angle grinder- with no ill effects to the rotors...
04-25-2009, 03:06 PM | #11 |
Señor Member
Current wheels have been capless for 10 years (next month), so as you can see, I am flexible on this point
