Old 04-22-2009, 08:38 PM   #1
Penix
Penix's Avatar
1967 C20 with 275/60-17's on all four... Will they fit? What BS is needed to fit?
First of all, will these even fit in all four corners? Second, what back spacing would I need to bring the rubber right to the edge of the fender?
I want to keep all four wheels/tires the same size so I can easily cross rotate them.
This truck is almost 100% stock as it sits right now, but I'm sure as hell not leave'n it that way I'd like to lower it eventually, but wheel/tire size is more important at this point since the ones that are on it REALLY need to be replaced.
Was considering a 5 on 5 swap but now I'm kind of think'n bout stick'n with the 8 on 6.5, who knows which way I'll end up go'n LOL
Take care guys! Thanks in advance!
- Joel
"Don't get on it if you can't stay in it" "How do you call yourself a man when you're ride'n a pony?"
Penix is offline   Reply With Quote
Old 04-22-2009, 10:18 PM   #2
morgan71
Re: 1967 C20 with 275/60-17's on all four... Will they fit? What BS is needed to fit?
If you have plans of lowering I would go with a 255 60 17. The 275 60 will be a little taller which will give you problems up front. I think that tire is about 31 tall. I had a set of General Grabber 255 60 17 on my truck they looked great. I believe my wheels where 8 wide with 4 backspace. Sold the truck so I cant measure for you.
morgan71 is offline   Reply With Quote
Old 04-23-2009, 01:56 PM   #3
Penix
Penix's Avatar
275/60-17 = 29.99" x 10.83"
255/60-17 = 29.05" x 10.04"
So the 275's are an inch taller and about 3/4" wider...
I was thinking about lowering it 2/3, but not if it's gonna make me go with smaller tires, these trucks look GREAT with taller tires!
What about 31" x 10.5"? Haha I know it's 2WD but I like bigger tires, I can't help it!
Old 08-15-2009, 12:59 AM   #4
drumdoc
I know im late on this one but just joined. I have a custom camper 20, 2 wheel drive and have 31x10.50x16.5 on it BFG radial TA All Terrains. No Problem with these on the truck. I need new tires and wanted something wider with a lower profile, more street looking. I have struggled for months trying to find wheels and tires. If it were a c10 1/2 ton no prob. If I go to a 16 or 17 the max tire width will be less than i have now. If I go to a 20" Then I can get a short but wider 10 ply tire at almost $300.00 ea. Needless to say im still looking.
drumdoc is offline   Reply With Quote
